Use an Ethernet cable to connect a computer to a port on the router.
Access the router's built-in web-interface, and run the "Wireless Networking Setup Wizard", to configure your wireless network,
and pick an SSID and pick a password.
Then, after restarting the router, enable the wireless networking on your iPod Touch, and it should find your SSID. Enter your password, and you will get connected.
You will need to check the wireless settings of
the router.
If your network is secured then make sure that you
are typing the correct network key.
also make sure that the DHCP server is enabled on
the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
Click here for step by step instructions
SOURCE: Linksys Wireless-G 2.4GHz Broadband Router
If you press and hold the button o the back of the router that says reset for 30 seconds, the router will restore factory defaults. Then, your routers password will be reset to "admin"
SOURCE: i cant connect my ipod touch to my linksys WRT160N
hi! check first the wireless settings of your router, it may be set only to connect wireless n adpater, u have to set it on all wireless, b,g,n, if the settings is not set to all u will not able to use ur ipod touch to connect, I bliv ipod touch wireless adapter is wireless g. check also the wireless security settings if ssid is not broadcast, make it broadcast or if u dont like to broadcast it, just remember the ssid and try to check as well the wireless settings of ur ipod touch..
SOURCE: Can't connect my router to my Ipod touch?
ok do this if it is already showing your router up on your portable device but it has that security lock and you are unable to join or need a password which u dont know lol go to that network and on the top push forget this network. than go back and click on for other location. than for the name put in your router name usually 5 characters long make sure u use capitalization cuz its case sensitive. than select what kind of key u have it should say right on the side of your wireless router. than type the key in usually a wep key and u should be set to join it if it doesnt auto matically do soo
Turn on your iPod Touch or iPhone by pressing the top button. Wait for your iPod Touch to boot and slide your finger across the lock slider to unlock the device. You will now at the iPod Touch home screen
Press the Settings icon on the iPod Touch Home screen to change your system settings. Click on Wi-Fi near the top of the Settings menu. A list of available wireless access points will load.
Find your Linksys wireless access point from the wireless device list under the Wi-Fi menu. If you have already setup an security key for your Linksys router, you will be asked to enter the key after selecting it from the list. Press OK and wait as it connects to the router. Enjoy the added benefit of having your iPod connected to the Internet.
