I have an e74 error message with 1 red light
The E74 error happens as the scaler chip that deals with all the display, you will need to stop the heat build up, you can do this yourself or you can send it in for repair.
E74 is a the notorious overheated error. Have to send it back to microsoft. They extended the warrenty to 3 years of the date on the back of your xbox if you get the e74 error. Go to xbox.com and click services. you type in your serial number and it will tell you if its still under warrenty.
SOURCE: one red light flashing error code E74
Is it still under warranty?
Call the company and get an online tech.
I had to send mine back...
It took a week to receive a box from the company and about 6 weeks to get it back.
I forgot about it!
It takes a while, but works well!
SOURCE: XBOX ERROR
3 Red lights problem is one of the most common problem of Xbox 360. You willhave to either get it repaired from Microsoft (in case your Xbox'swarranty is not expired, but one thing to note is that you will have towait for at least 3-4 weeks to get back your Xbox) or you can Fix yourXbox error yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
SOURCE: system error e74
The cause of the E74 Error might be overheating of
your console and for avoiding such error messages in future you need to
put your machine at an open space. Ensure that it is placed near the
window or you can also make some external arrangement for cooling the
console such as cooling the machine through a pedestal fan etc. But as
your Xbox already have E74 Problem, You can either send your Xbox to
Microsoft for repair ( just for your information Microsoft is no longer
providing Extended warranty for E74 Problem), Microsoft generally takes
3-4 weeks to fix the problem. If you can't wait for a month (I know
most XBox gamers can not wait without their favourite Gaming device),
You can also fix E74 Problem yourself and that too within an hour
without any technical knowledge. I would suggest you to check out the DIY Xbox Fix Guide for more information.
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Back to the top
CAUSE
This problem occurs when the Xbox 360 console experiences a hardware failure.
Back to the top
MORE INFORMATION
Step 1: Confirm the E74 errorTo verify that your console is displaying the E74 error message, follow these steps:
1.
Turn off the console.
2.
Turn on the console.
3.
Verify that your console displays the E74 error message.
Back to the top
Step 2: Submit a console repair requestIf you are experiencing this problem, you can submit a console-repair request online by using the links in the "Additional support" section.
Back to the top
Additional supportIf your console continues to display the E74 error message, it requires a repair. There are no additional troubleshooting steps. To start the online repair process, click one of the following links:
In the United States
http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair)
Outside the United States
http://www.xbox.com/support/ (http://www.xbox.com/support/)
Note Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox support directly, please visit the following Web site:
http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error. For more information about this repair process, click the following article number to view the article in the Microsoft Knowledge Base:
969905 (http://support.microsoft.com/kb/969905/ ) About the E74 warranty extension for Xbox 360 consoles
Back to the top
References/Links
If one light around the power button on your Xbox 360 console flashes red, there are additional steps that you can try. For more information, click the following article number to view the article in the Microsoft Knowledge Base:
907536 (http://support.microsoft.com/kb/907536/ ) One light flashes red on your Xbox 360 console
