Apple iPod nano Logo
Posted on Dec 27, 2009
I locked my Ipod and i cant remember the lock code
Last night i locked my ipod and in the morning i couldn't remember the code and i cant stop it from playing songs what do i do???
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 27, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
317
Points
Restore your iPod via itunes, it will take away all your photos/music on your iPod but it will take away the code!
How much to fix ipod touch screen and where
Good morning, afternoon, evening or night; whatever time of day you receive this. You want to know how much to fix the touch screen and where to fix it? I want this solution to benefit you as much as possible. Having to pay for someone to fix your iPod touch screen should be your last result. I'm tell you some options you can try that may save you a few dollars and having someone to fix the iPod touch screen. I don't if this is the problem, but the touch screen may be locked. Automatically, the iPod touch locks when there has been no activity for a certain amount of time. To unlock the touch screen, press and hold the Home button or the On/Off/Sleep/Wake button which is located at the top of your device, and then drag the slider. If you want to set the amount of time before Auto-Lock activates, press Settings, General, Auto-Lock; then set your preferred time. If that doesn't fix the problem, you can try a system reset. To do this, press and hold the Home and On/Off/Sleep/Wake buttons together for approximately 10 seconds until the Apple logo appears on your screen. If this doesn't work, you can take your iPod Touch to your local Apple Retail store and have an Apple technician work on it for you. There will be a fee for diagnostic services. You can also contact Apple Technical Support or Online Service Assistant. For more contact information, go to this website (http://www.apple.com/support/contact/). I hope the problem is just a screen lock up and if you have to get a repair or replacement, it won't burn a hole in your pocket. Thank you for choosing FixYa as your one-stop solution spot for your problems and requests. Have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
Ok so i changed my passcode last night,because i didnt want a friend to get into it(he knew the pc) and then i went to play on it this morning and i didnt remember it... i disabled it.:( then im coneecting...
this can be fixed by restoring the ipod.
plug into computer and turn the ipod off (hold power button, wait for slider, turn off). turn on by holding the power button and the home key at the same time, this puts it in restore mode, yellow sign should appear. start itunes. click on the summary tab and click the restore button. this returns it to factory settings. if you want you can now choose a new passcode as you would normally on the ipod under settings
hope this helps =)
Yeah my ipod screen is locked i cant rember my four digidt comban
try restoring the ipod to its original settings when it is plugged into your computer.
My ipod stoped doing anything, it is locked on screen with message saying I have to wait over 2 billion minutes which is calculated to the ripe old age of 73, cant do anything
The iPod touch becomes locked when an invalid unlock code is entered too many times.
There are two ways you should be able to unlock the iPod.
The first is to connect it to the computer it was last synced with. After iTunes recognizes it, you should be able to unlock it.
If that doesn't work or you can't remember your unlock code, you will need to put the iPod into recovery mode, and then restore the iPod through iTunes.
To do this:
1) Turn the iPod off.
2) Hold down the iPod's Home button and plug the iPod into the computer it was last synced with.
3) Release the Home button when the iTunes image appears on the iPod's screen.
4) Wait for iTunes to recognize that the iPod is in recovery mode, and then follow the onscreen instructions to restore the iPod.
Note: You may lose some of the information stored on the iPod.
If you cannot unlock the iPod after doing this, you will need to call Apple Customer Support.
1helpful
Cant unlock my ipod nano.
Hi
To unlock your ipod you'll need to connect it with the pc it is last synced to. After connecting it open itunes and from the main screen click on restore, it will unlock your ipod.
Remember after restoring you'll lose the menu settings and other settings saved on your ipod however no data will be deleted from the ipod.
Please accept the solution and revert for further assistance.
Thanks
Rylee
Ipod lock code
If you can't remember your lock code on your Nano, you will have to restore the Nano via iTunes, there is no other way around this, as there is no way to recover your lock code.
Restoring your Nano will erase everything on the player, and restore it to factory defaults, after this is done you can restore all your files and settings to your Nano.
Here is instructions on resoring your Nano in case you aren't sure how.
http://support.apple.com/kb/HT1339?viewlocale=en_US
1helpful
2answers
Cant open ipod touch its locked
okay for all those who cant remember their password code pls follow this http://www.youtube.com/watch?v=cenCotyWRbM
pls follow the instructions given
if this help pass it on and feel free to rate the help given
unlocking ..............................................
My ipod is locked
if you really tried everything, then call apple for it, that iPod must have some factory defects..
My ipod doesnt powre on
The 5 Rs: Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with iPod nano. Try
these steps one at a time until your issue is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
â Reset iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer, and make sure you have the latest software updates
installed.
â Reinstall iTunes software from the latest version on the web.
â Restore iPod nano. See “Updating and Restoring iPod nano Software” on page 50.
4helpful
4answers
Help with ipod 8gb nano
Reset your Ipod using the following procedure:
Turn hold on (lock)
Turn hold off (unlock)
Hold in Menu button and middle button until Ipod shuts down and starts up again.
This should remove the lock on the Ipod.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
