If your 2007 Chevy Impala is making a clicking noise before the key is even inserted into the ignition, it could be caused by a few different issues. Some potential causes include:
Faulty starter motor: The starter motor is responsible for starting the engine when the ignition is turned on. If the starter motor is faulty or has worn out, it may make a clicking noise as it tries to engage with the flywheel.
Loose or damaged starter motor relay: The starter motor relay is an electrical component that sends power to the starter motor when the ignition is turned on. If the relay is loose or damaged, it may cause a clicking noise.
Low battery: If the battery is low on charge or has gone bad, it may not have enough power to start the engine, causing a clicking noise.
Other electrical issues: There may be other electrical issues, such as a loose connection or a problem with the ignition switch, that are causing the clicking noise.
To determine the cause of the clicking noise, it is recommended to bring your vehicle to a mechanic or a dealership for further diagnosis and repair. They will be able to test the starter motor, battery, and other electrical components to determine the source of the problem and recommend the appropriate repairs.
I believe those older cars used circuit breakers, not relays, for the power window systems. By using a test light, you don't know if battery voltage is present at the window switch. Maybe the voltage is reduced, somehow.
I would first check the switch's power with a voltmeter. If the motor is getting battery voltage, I would say the motor. If the voltage is low,
you had better find a wiring diagram, Dave, to trace it out.
The loud Click click click isn't because the starter is bad it is because your battery doesn't have enough power to kick it over. Change your battery. The click will stop. Harley starters either spin without making any click noises or don't make any noise when they go bad.
Do you hear a clicking noise when you turn your truck on? Its probably the actuator. While the defroster was on I removed the fuse locted under the rear driver side seat. I think its 36B. It stopped the clicking noise and my air vents work well now.
The click noise is the sound of the starter SOLENOID clicking but not contacting to supply voltage to the starter motor.
Now a multimeter test will confirm if the solenoid is contacting and if so then the starter motor is faulty.
It can be due failure of the BRUSH in the motor or the commutator. If so remove the motor and confirm.
Also if the starter pinion is struck the solenoid will click and the motor may not turn.
I have and 2002 with rear air and had the same noise and problem in the back. There is motor in the back that moves a flapper door open and closed to blend the hot and cold. The motor has plastic gears in it and they strip out making a clicking noise when the motor cannot hit the point that the heat control dial is being set too. Probably the same set under the front dash. You will more than likely need to by a new motor assy.
Clicking?... not knowing which clicking noise you are hearing, I will run down the most likely on a new pump.
1. When wiring the motor you may have left a wire in close proximity to the centrifical start capacitor switch. It spins at high RPMs and can be hitting a wire not properly tucked in
2. Most pool pumps are dual voltage. If you wired motor for wrong voltage than that being delivered, the motors can sometimes make noises. Clicking isn't most common, but the vibrating hum of incorrect voltage might be interpreted as a clicking noise.
3.check to make sure no wire ties, or plastic stringy tag holding devices were left in the pump intake basket.
Is the noise clicking consistantly?or just on again off again?Yes there may be a faulty motor.Try removing the wires and tape them up then run the unit if there is still noise need more info .And to let you know yes they can be made into a low quality air compressor:) hope i helped :)
you have 3 choices.
1) Bad battery
2)Starter motor solenoid is inoperative or starter motor itself is inoperative
3) your engine is locked up
How old is your battery and are the connections to the starter motor good?
Do you hear a clicking noise when you try to start the engine?
Do you have a clunk noise when you try to start it?
If dirty connections then clean the terminals andtry to start engine.
Clicking noise means starter solenoid is picking up but starter motor is disunctional and needs replacement.
If the noise is a clunk then your engine is locked up for whatever reason.
Last but not least if you hear the starter motor runningand a metalic grinding then the star is bad on the starter motor which means replacement of same.
