How do i send music from my LG P350 phone to another phone?
Hi, you can transfer music from your phone through blue tooth.
What you'll need:
Bluetooth Enabled Phone
About 5 - 10 minutes (Depending on your phones Bluetooth speed and your patience.
Step 1: Powering on Bluetooth
First off, we will need to power your Bluetooth antenna on. To do this, please complete the following:
Go to the Main Menu (by pressing the Menu key on your phone
Go to the Settings button (usually looks like a wrench and screwdriver
Scroll down to "Connections" and press the Enter button (usually in the center of the multidirectional mouse. If you don't know what that is you can press "Select" on the top LEFT or top RIGHT buttons on your phone keypad).
Go to Bluetooth Link
Go down to "Setup"
Select Power
Make sure that there is a check mark next to the "ON" option
You may now press the END key on your phone (or close it and open it again)
# 4
Step 2: Sending the File
In this step, you will learn how to send a simple file (A graphic, Ringtone or Address Book entry. For this article we will learn with a Ringtone. Please note that you MUST have a Non-Motorola ringtone (so you can't use Cingular tune for copyright purposes).
Please follow these steps:
Go to the Main Menu.
Go to My Stuff
Go to Sounds (which may be labeled as something else)
Find the ringtone you wish to send.
Press the Menu button (Or use the appropriate soft key, or the key in the very upper left or right hand corner of the phone keypad)
Go to Manage
Go to "Copy" (NOT move)
Select Bluetooth
Go to Look for Devices (if it is not the only thing on the list)
It should display a message stating "Scanning" and under that "Devices Found: #". (# = Number of Bluetooth enabled devices in range)
After this is finished, select the phone by which you would like to send the file.
Press Select
Check the phone you are sending the file to and make sure it is sending properly. You may need to okay this from the other phone. If you are asked for a password usually
Tips & Warnings
Make sure you do this on BOTH Phones and NOT just the one you are sending the file from.
