Basic steps to follow:1. Replace your IDE/SATA cable (cable that connects to motherboard to local (system drive). 2. Check if there's a dirt build-up on RAM pins (clean it via pencil eraser then cotton with 70% alcohol or dirt/rust cleaning solution. 3. Same process on step #2 as for your grahics card if there's any. 4. Graphics card cooling system maybe overheating, try touching it, if it is, replace the cooling fan if you can(also the thermal paste) 5. Try your built-in (on-board graphics card alone, by removing the inserted video card. If your PC worked normally then the problem is on the inserted Vcard. If the prob still exist then the defect is on the built-in graphics processing unit of the board that needs a major repair by reballing the onboard video chip.
There is no Fn-Fx key combination to change screen resolution (at leat on my R10 running Windows XP. Even if you create a shortcut to open the graphics properties you still have to open the relevant tab manually to change resolutions. You can open the Intel Extreme Graphics 2 for mobile icon on the tray, go to the graphic properties change the resolution and save as a scheme. With a customized scheme defined you will be able to click the Intel Graphic properties and select that scheme. But be careful, your tablet pen will no longer be calibrated with the available screen area. I tried on my R10 (native resolution 1024x768) and all I could select was 800x600@ 60Hz.
1. check the RAM is seated 2. Try any other RAM 3. still the same problem check the video or graphics card , if any 4. if no graphics card and problem stiil changing it clear your CMOS by removing battery 5. if its new system then, remove battery, then take a small wire piece and short the positive and negative of the battery socket, then only CMOS is cleared 6. still problem , check the processor heat sink 7. still problem then suggesting checking motherboard and processor
Please post your feedback and Vote if the problem resolved as per your satisfaction.
If an external monitor showed graphics, then there is nothing wrong with your Graphics 'chip'.
{'Chip' is a slang term for IC. Integrated Circuit.
The Integrated Circuit for graphics is a GPU. Graphics Processing Unit. Your laptop uses the Nvidia GeForce G0 FX5200 GPU.
Your laptop like many others, does not have a graphics adapter card. It has Integrated Graphics. Another term is 'OnBoard'. The graphics chip is on the board. Motherboard. There is no graphics adapter card to remove, and replace}
Some areas you may wish to address:
1.The Native Resolution is 1400 X 1050. What does it state in Display Properties? (Right-click on any empty area of your desktop screen. Click on Properties at the bottom of the list. Click on the Settings tab)
2.There are known issues with the CMI display cable. Observe the display cable. Look at the letter/numbers under the barcode. Does it start with CMI?
3.There have been known issues with the connectors on digitizer cable http://www.irisvista.com/tech/laptops/ToshibaM200/Portege_M200_digitizer_2.htm (The above is for reference to the digitizer cable identification)
If you have run the laptop in safe mode it uses the standard VGA graphics driver, and this indicates the onboard graphics card is still functioning. Try connecting and external monitor to your laptop and the boot up your laptop. Then :- 1. Download the latest graphics driver from ASUS WEB site. 2. uninstall the graphics driver. 3. Reboot the laptop and install the new graphics driver. 4. Shut down and remove the external monitor and reboot. 5. Goto the Control panel - Display and check/set the settings for screen resolution, Colour setting etc.
no. i think your monitor is old. some time we get voilatie or red screen .some time it take short or long time. and some time screen moving. main cause is lose joint part in monitor it can be fixeb by soilding every parts by expert.for conform u change other monitor.then u can get result . thanks
without actually having a chip to complement your sound 'card' you're not really going to have hardware capability ... just just a shared state where available memory for use by sound is deducted from available standard ram ...
your graphx card is also integrated ... ( hehe .. i've actually had someone ask me to upgrade their laptops video card .... )
