You made a good choice. In the CPU arena right now, the difference between the two CPUs is a toss up. The slight advantages of one vs. the other in benchmark tests is nominal and actually artificial..
What happens with an AMD CPU is with the associated GPU onboard. And with a 64bit processor, the number of apps and games that take advantage of 64bit CPUs has always been limited but they are growing. This will only become more and more numerous.
The main architectural difference in the two was in how the two cpus communicated and the AMD was first to use a bus between the two cores and the Intel had to go to the onboard memory controller and back. That was in the first inception. Still, AMD has been far in advance of Intel and Intel has played catch up in tricks inside the cores and how the north and southbridge took advantage of the cores' architecture.
Needless to say, I'm an AMD power user and my gaming rig has an AMD dual core on an Asus/Nvidia board and an Nvidia PCIe 9800 GPU.
In the long run, all modern notebooks require you to own a pad cooler to use these in your lap or not, they all produce heat. So, just get a good one designed for your laptop so it snaps into place and will keep your rig nice and cool.
At a LAN Party you won't suffer from having a dual core AMD cpu, you'll hold your own and it will be an even playing field and the wins will go to the person with the fastest fingers... as it should be.
Core 2 Duo is a Brand name by intel to identify his class of Dual core CPU
a Dual core CPU is basically two CPU in one package, which dramatically improves performance over previous architectures.
Pentium Dual Core is another brand name by Intel to identify his new entry level CPU offer.Basically Pentium dual-core are similar to Core 2 Duos except they(pentiums) are slower and cheaper. they both are dual core CPUs. I would prefer a core 2 Duo having to choose a laptop because of better performance, but the prize is different for the two solutions.
Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo").
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM
But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14.
http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
