Question about Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT
Primer bulb will not fill - Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT
    Scholar:
  • 84 Answers
This answer assumes you've put gas mix in the fuel tank.
Unless the saw is new (and possibly even if it is) there are only three things which can cause this:
1) The primer bulb is split or has a small hole in it (they rot and split often, but are not much trouble to replace)
2) The line between the bulb mount and the fuel tank is split or has fallen/been pulled off (this frequently occurs as well)
3) The fuel tank filter has trash on it and is preventing the prime. (this is harder to check and/or fix, but not impossible- and all of these are cheap!)
Posted on Dec 26, 2009
    President:
  • 2,220 Answers
Typical Fuel System (Primer Bulb and fuel lines may not apply)
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but on multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
6ya staff
SOURCE:
Why won't primer bulb fill on homelite 26cs weadeater?
a primer bulb should not actually fill, that said, if it is not priming your carb then there might be a tiny crack or pin hole that is letting air in as you try to prime, order and change the primer bulb.
Oct 16, 2016 | Homelite Garden
RY28100 primer bulb does not fill. New bulb, new fuel lines & filter, plus carb newly rebuilt. Still doesn't fill bulb or start!
Does it have a base to the primer which sits on the carb.? Have you connected the pipes correctly.??
May 19, 2016 | Ryobi Garden
The primer bulb doesn't fill with gas
sounds like you hasve a cracked fuel line or a cracked primer bulb. that is why it cant prime.
Aug 29, 2015 | Swisher 190cc 22" String Trimmer Mower...
How to rout fuel lines to primer bulb on poulan 14" chainsaw
Short line on primer bulb goes to the left side of the carb. The long side on the primer bulb goes to in the fuel tank as the return line.
Jul 23, 2014 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Stihl chainsaw primer bulb will not fill. Puts pressure in fuel tank
try switching the tubes on the back of the primer bulb
Nov 12, 2013 | Stihl Garden
I can't get it to start. Don't think the gas is moving when I pump it to start it. When I push on the bulb, it doesn't appear to pick up fuel.
Is the primer bulb filling with fuel.? If not then you either have a hole in the primer bulb or a hole in the fuel line, you mat also have a blocked primer bulb base.
Aug 03, 2013 | Garden
Vapor lock
The tank vent is a bronze plug inserted into the tank casting--the caps are not intended to vent. Check the fuel filter for plugging and the condition of the fuel lines and primer bulb. You should be able to fill the bulb with fuel after several pushes of the primer bulb. Have the fuel lines been changed? Hope this helps!
Apr 12, 2010 | Poulan Pro Chain Saw 46cc 20"
Primer bulb won't re-fill.
Not sure about your particular set-up, but there is usually two fuel lines running from the fuel tank. One goes to the carb and the other goes on a fitting on back of the primer bulb. The primer bulb will have a second fitting with a line going to carb. Sounds like either a clogged or leaking fuel line to me. Hope this helps and good luck.
Jul 11, 2009 | Garden
Poulan Wild Thing 18" 40cc Gas Chainsaw - P4018WT Logo
3,195 people viewed this question
Top Poulan Tools & Hardware - Others Experts
Bill Boyd
Brandon Bruce
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
