Question about Cellular Innovations Radio Communications
HFBLU-H300 bluetooth headset does not pair up completely with AT&T Tilt2. The headset will not give a prompt for the pin#, yet it installs & will let you activate a command such as "call" through the headset then brings up the number, verifies the number to be called but dies there. It will not dial.
6ya staff
SOURCE:
Anonymous
SOURCE: just got bluetooth and no pin someone help me plz
The pin number ginen in the instruction manual is 0000.
Posted on Feb 06, 2008
digitalain
SOURCE: HFBLU-LT100 pairing a second phone
Canadian Tire's HFBLU-LT100 (BK-600) won't connect to my SPH-m300 Samsung phone but I entry of the passcode (0000) about 20 times before it connect successfully.
Posted on Dec 02, 2008
Anonymous
SOURCE: LG bluetooth hbm 760 pin number
The pin is 0000.
Posted on Feb 24, 2009
Anonymous
  • 464 Answers
SOURCE: pairing ny bluetooth headset with cellphone
it's always 0000
Posted on Mar 18, 2009
Anonymous
SOURCE: need pin number for Cellular Innovations Hfblu-1k 5-Piece Bluetoo
The oin number is 0000
Posted on Oct 16, 2009
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
Can you set the H300 to pairing mode
startingwith the power off push and hold the call button while the head set turns on....then continue holding the call button until the light turns blue that has enabled the pairing mode now the pin code for all h300 model bluetooth device is 0000..i hope this helps
Feb 01, 2011 | Motorola Mobility H300 Wireless Headset
I put my HFBLU-LT200 bluetooth headset on charger and both blue and red light have turned on permanently. Bluetooth has stopped working
That usually means it isin pairing mode. Charging some headsets from extended periods can sometimes reset the device requiring you to pair the device again.
Feb 04, 2010 | Cellular Innovations HFBLU-AX1 Bluetooth...
HFBLU-LT100BK Bluetooth keeps "pairing failed"
headset won't pair with me phone and i have tried 0000 and 1234 and 12345
Jan 30, 2009 | Cellular Innovations HFBLU-CX1 Wireless...
Need to setup H300 bluetooth to my LG VU phone! How do I do this?
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
Jan 08, 2009 | Motorola Mobility H300 Wireless Headset
Pairing bluetooth with new phone
You have to hold the on button until it is a solid blue light not flashing 5 or 6 seconds then it is ready to be paired.
Jun 21, 2008 | Motorola Mobility H300 Wireless Headset
Need a users guide (instructions)
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
Jun 12, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
BT pairing code
Jan 15, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
Radio Communications Logo
240 people viewed this question
Top Cellular Innovations Radio Communications Experts
Anthony Ward
Anthony Ward
Marvin
Marvin
Are you a Cellular Innovations Radio Communication Expert? Answer questions, earn points and help others
