Televison & Video Logo
Posted on Dec 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Green light comes on then goes right back off.
I have a Mitsubishi HD 1080 Diamond rear projection that is about five years old. I held the menu and device button down to get the code. It blinked 2 blinks, paused, 2 blinks, paused, 2 blinks, paused, 2 blinks, paused, 2 blinks, paused, 2 blinks, paused, 2 blinks, paused, 2 blinks, paused, 2 blinks, paused, 2 blinks. In other words10 sets of two blinks. Please help. Sure puts a damper on Christmas! What is the problem/solution? Thanks, Brad
  • Anonymous Mar 21, 2014
    My mitsubishi 60in tv wd 60735 holding the menu and input buttons the light blinks 1 pause 2 what does this mean?
Arnel
Level 2:
Sergeant:
  • Expert 184 Answers
  • Posted on Dec 26, 2009
Arnel
Expert
Level 2:
Sergeant:
Answers
184
Questions
Helped
52291
Points
518
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
1helpful
My Mitsubishi Medallion tv stays on for about 10 minutes and then shuts down and won't turn back on until a period of time has passed. It is a rear projection tv about 9 years old. Can anyone help ex
When it shuts off and the green power light goes off, press both the menu and input buttons on the front of the set (not the remote) and hold both for about five seconds and release.
Power light will blink a two digit error code like 2 blinks and then 3 blinks and repeat it several times.
What is the error code?
6helpful
Power will not stay on
Based on the model number WS65511, this set has a self check.
Turn on and when green power light goes out:
On the front of the set press and hold BOTH the MENU and INPUT buttons for at least 5 seconds and then release both buttons.
Power light will blink a two digit "error" code.
The most common is 2 blinks, a pause and 2 blinks. Set will repeat the error code at least 5 times.
Let me know what error code you find and I will tell you what it means, I hope you find it is 2,2 as that is the most easy to fix.
SD TECH Steve
13helpful
2answers
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
2answers
Warped 3-D LOOK COMES AND GOES
resolder the convergence ICs . Common problem with mitsubishi rear projections
8helpful
3answers
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
1helpful
My 2001Mitsubishi 1080 hd Won't come on
Most Mits. models like yours will need a DM module repair or
replacement----either way, about 600.00.....T.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
