Question about Honeywell HE220A1019 Whole House Humidifier Humidifier
Works too well, can't stop windows from sweating!
I installed the HE220A humidifier in October, with the humidistat and flow switch. As soon as the outdoor temperatures dropped I had very heavy sweating on every window in the house, enough to puddle water on the sills and woodwork and cause mold to grow. For weeks I played around with the humidistat setting without any change in the amount of sweating. I also reduced the water flow to the unit so there is barely any water coming down the drain. This also resulted in no change. Finally I unplugged the humidifier and within one day my windows were dry. I wonder if the humidistat is faulty. Is there a way for me to test it? Is there any other way to reduce the capacity of the unit besides reducing the flow of water to it?
  • Anonymous Jan 20, 2009
    CANT STOP WINDOWS FROM SWEATING THANKS
  • Anonymous May 11, 2010
    Is there a bypass damper in the unit or the transfer duct? Also if you have a multimeter, you can diconnect the humidistat and ohm it out. Steve
  • Honeywell Master
  • 6,023 Answers
I don't know much about humidifiers other than they are rarely needed and most folk around here would rather there was a lot less humidity., especially considering how easily black mould grows and how injurious to health that can be.
Those few people living with an unsuitable heating system in a badly designed house usually find it is adequate to have a water feature in the lounge or to balance a bowl of water on a radiator.
Certainly when the windows sweat to such a degree, especially if you have double glazing, the humidity must be well above the comfort range, above 70%, and probably well into the moist range of 80% - 90%. Higher than that and any exertion becomes decidedly unconfortable...
I am guessing the humidistat is either faulty or cannot work because the humidity is already too high. I suggest you need to check the humidity in your home with an accurate independent humidity meter before you go further...
Posted on Mar 25, 2017
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Continous ware flow on Honeywell HE220A Humidifier
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found: http://www.iaqsource.com/product.php/honeywell/32001639-002/?product=112783&category=1142
Posted on Nov 20, 2008
Anonymous
SOURCE: he220a honeywell humidifier water actuator valve broke
My problem was the input water pressure (someone apparently changed it). I did, however, remove the unit and clean the filter which was pretty gunked up and that, along with adjusting the water pressure going into the solenoid, appears to have solved the problem.
Thanks to all who responded.
Posted on Dec 09, 2008
mrgrzz
Dale Koehn
  • 88 Answers
SOURCE: HE220A direct wiring to protech 62-24084 control board
it is best to use a seperate transformer for the hummidifier, but in some cases you can use the low voltage t-stat wire that runs your furnace, you will need to have one wire run to common, and the other to the heating side of your low voltage, normally its the red wire hooked to the w circuit of your terminal board, if you do decide to go with an extra transformer, make sure you you have it wired to bring on the humidifier only when the unit calls for heat, hope that helps
Posted on Jan 20, 2009
Anonymous
  • 8 Answers
SOURCE: Wiring issue with the Honeywell HE360A Humidifier
Maybe I can help. this is 24v so it doestn't matter which wire goes where so here goes. 2 wires from humidistat go to furnace, split one of the wires(not both) so they reach the yellow wires on the humidifier. with marettsconnect one of the split wires to one of the yellow wires. do the same to the other split wire and yellow wire. what you should get is one wire from humidistat to furnace then one wire from humidifier to humidistat and one from humidifier to furnace. hope this helps
Posted on Feb 04, 2009
Humidifier Running Continuously with Fan Blower
As long as the humidifier start/stop is regulated by air flow there is no way to cycle it on/off with another device. If, however you disconnect that capability and, instead wire it to the heat on cool on switch it will only turn on when the stat calls for heating or cooling. You may need to install an intermediate relay off the stat wires to regulate the different(assuming that they are) voltage of the humidifier start/stop.What a fun project, thanks!
Jan 22, 2013 | Humidifiers
I have just completed installing a Honeywell HE220A humidifier to a Carrier Weathermaker 8000vs that was installed in 2003. My problem is that all the identified circuits in previous posts on the circuit...
I believe that Carrier has a 24 volt setup for humidifier but am not sure. On the circuit board I think there is a terminal (HUM). If there is this terminal connect 1 wire to this and 1 wire to C terminal.
If not,pretty sure there is a 120 volt EAC terminal. This would only kick on when blower is on. If you have to use this you would have to install transformer to the EAC connections
Jan 28, 2011 | Honeywell HE220A1019 Whole House...
I have a Honeywell House humidifier HE 225A-1006.
In order of probability:
1) (incorrect wiring) Make sure that humidistat is in SERIES wired with the furnace.
2) (shorted wires) Check that two wires to humidistat are not touching...use your glasses if you need them!
3) (bad humidistat) disconnect the humidistat and put an ohmmeter accoss the two terminals when it is turned on you should read 0 ohms, and when off it should read infinate ohms, if not pass both these tests, you need new humidistat.
That is it, there are no other possibilites!
Oct 12, 2009 | Honeywell HE220A1019 Whole House...
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
Jan 19, 2009 | Honeywell HE260A1010 Whole House...
Honeywell he220a install
thanks for your question,
you have to install the bypass humidifier on the supply side of your heating system, (hot side) and run a bypass pipe from the return side, (cold side), it does matter which side it goes on, you do not want water vapor going directly into your furnace, as this can damage it and shorten the life of it, your humidistat is installed on the return side of your duct work, this will allow proper operation of the unit as the humidistat senses the moisture in the air and brings on and shuts down the humidifier as needed. hope that helped to answer your question, please let us know what you think, again thanks, mr.grzz
Jan 17, 2009 | Honeywell HE220A1019 Whole House...
Honeywell he220a waterflow
Sounds like you Connected the humid trans fromer directly to a main power source. It should be either on the EAC or HUM term on the board of the furnace.
Dec 11, 2008 | Honeywell HE220A1019 Whole House...
I have the HE265B By-Pass Flow-Through Hunidifiers installed in the summer, but it never on, until this fall, I tried to turn, but no water flow through. How can I test it? The contractor is NOT...
first break or loosen the water line connection at the humidifier and if you get water then you know it is something else. While the heat is running and main blower is also running, turn the humidistat from low to high; if you hear a click in the solenoid valve (where you checked the water) then you know it has power and the humidistat works. anything deyond that call a good contractor.
Nov 21, 2008 | Honeywell Power Humidifier: Furnace...
Oct 18, 2008 | Honeywell HE220A1019 Whole House...
Humdifier on furnace
I have the exact same problem. At this time I am looking for a new solinoid (part on the bottom) to install. Anyone else having this problem and know where to find replacement parts
Jan 22, 2008 | Aprilaire 700 Humidifier
Honeywell HE220A1019 Whole House Humidifier Humidifier Logo
837 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
