Question about Kenmore Elite 45986 Front Load Washer
He3 elite kenmore- sUD and F21 error - Kenmore Elite 45986 Front Load Washer
  • Anonymous May 11, 2010
    Hello there tbird I had the same thing happen and i had to run the cycle again with out any cloths in it due to too much detergent but now it works fine after i did this thanks
  • Kenmore Master
  • 3,051 Answers
Hello there"
Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Posted on Dec 26, 2009
2 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: kenmore elite he3 front load
I had the same issue with a brand new wash. The issue I found was the installers installed the drain line too low. The drain line needs to be a minimum of 39" above the floor. Hope this helps -- Kent
Posted on Nov 11, 2008
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Tip
    F21 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washers
    This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
    “F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
    1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
    2. Check the drain hose to make sure it is not kinked or clogged.
    3. Check the electrical connections to the pump and ensure the pump is running.
    4. Remove the drain pump filter and check for foreign objects and/or debris.
    To check the drain pump, click on the following link for step-by-step instructions.
    http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
    If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
    on Apr 05, 2010 | Kenmore Elite 45986 Front Load Washer
    Tip
    on Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
    ERROR CODE F09
    A typical HE3 Kenmore Elite washer the F09 code indicates and overflow has been sensed. This can be because of suds or a failure of the pump or pressure switch.
    Suds is a common problem with the newer 2X-3X super concentrated detergents.
    A pump that is partially blocked might cause this error
    Oct 06, 2014 | Washing Machines
    Kenmore elite hE3 washer has f32 code flashing. Door is locked and would not open.
    F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
    Dec 09, 2010 | Kenmore HE3T Washer
    How do you get to the drain filter on a kenmore elite he3 washer to clean it?
    The following link explains how to access the drain pump on a Kenmore Elite HE3 front loader to clean the drain pump:
    If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
    searspartsdirect.com
    pcappliancerepair.com
    repairclinic.com
    Prices vary between these sites, so shop all of them for the best deal.
    NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
    If you have any questions, please let me know. I hope this helps you.
    Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
    "suds" error in kenmore elite HE3 front loader washer
    Try a vinegar rinse or there are also defoaming products available.
    Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
    Kenmore elite he3 front load
    Oct 16, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    1,348 people viewed this question
    fordexpert
    Harvey Mahal
    Kristen Denison
    Kristen Denison
    Level 1 Expert
