I am assuming that you mean the tank pressure drops and that the compressor does not keep up as good as it use to. Check the basics first, make sure the tank is not full of water from condensate, check your air filter, and the belt tension. If that is all good then the first place would check is the valves in the cylinder head of the pump, but since I do not know the make and model I can only guess that it may have a reed type valve used in it, these pumps quite often will need the valve plates replaced and will restore the pump capacity back to normal.
