Iomega 360 GB USB 2.0 Desktop Hard Drive Logo
Posted on Dec 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Iomega external ego hard drive(360GigaBytes)will cause my H.P. Pavilion with windows 7 to randomly restart while transferring data.
Megasom
Level 3:
  • Master 699 Answers
  • Posted on Dec 25, 2009
Megasom
Master
Level 3:
Answers
699
Questions
0
Helped
235212
Points
2067
I had a similar 'rebooting' issue with my WD external drive caused by a faulty USB interface on my Desktop: if you have an external USB hub, try running your drive via the plug-in USB Hub to shield your external drive from your desktop inbuilt USB electronics..
1helpful
Iomega eGo Helium 1TB has a damaged PCB. Local 1TB Casing do detects the HDD and its Drives. BUT asks for Formating the Drives. Which case can be purchased. how to recover the data. ?
It might be tricky, but you can remove the hdd from its casing, and install into a pc with compatible connections as a slave drive. Make sure to handle the drive carefully, and try to copy any data you want to another drive on the pc, then run chkdsk X: /f /r on the affected drive.
Another possible solution is to rightclick on My Computer, Manage, go to the drive mangement menu, and rightclick on the drive, and import it into your system so that windows can recognize it.
Ive been using my iomega eGo external hard drive for a couple years now. Today, it wont show up when i plug it into my laptop. The LED is blinking, albeit in a very random rhythm. Any suggestions?
These are some of the most robust external drives available. But, everything breaks. The most likely cause is a failed controller in the case. Remove the drive and put it into a new case.
Windows 7 driver for160GB eGo USB 2.0 Portable Hard Drive?
According to the Iomega Support web site you do not need additional drivers for using your Iomega eGo drive with Windows 7 unless you have a USB 3.0 device.
See this Iomega document on what you should do if your drive is not detected on Windows 7
1helpful
2answers
I have two Iomega 1TB 2.0 USB eGo harddrives with the encyption utility. I have the Windows 7 O/S. Initially, I plugged both harddrives (eGo) into my laptop, and created the password for each of the...
Iomega Utility are not Specific to the current device.
My iomega ego external hard disk was working properly but when i connected it today the encryption utility show that-Iomega Utility are not Specific to the current device and no any area shown to type password. My drive contains lots of valuable data. How can I acess into my drive. But the virtual drive is shown.
I cannot transfer a large file to my external hard drive,basically avi file. every time i try,my system hangs,i then have to remove the usb cable only then a windows delayed write error pops out...but when...
right click on the external hard drive , click on properties , click on compatibility tab
tick box and high light win operating system that you have ( win xp, vista 7,8 etc) click apply then ok
indicates that it is a compatibility problem
3answers
How do you get the Iomega eGo Hellium 350GB hard drive to be recognized and initialized by Microsoft Vista Operating system? Have tried the instructions from Iomega and they do not work. The system...
one thing that is possible, is that you may have another drive letter assigned to the letter the iomega is trying to use.
Try this....Click on your start orb and type in Disk Management.
open the Disk Management utility in Windows and see if you see the iomega drive listed in the list of disks on the bottom.
If you DO see the iomega drive there, make sure it shows a healthy partition (It should say something like Fat 32 or NTFS as the file system type...if it shows "RAW" or "damaged" or something like that, you may need to erase and format the drive)
Then, try right clicking on the drive and choosing "Change Drive Letter and Paths..."
from there try a new drive letter in case you already have another peripheral using the drive letter the iomega drive is trying to grab. This could cause Windows to recognize the drive but still be unable to see it in your explorer.
Good Luck
How do I back up my computer with an iomega portable hard drive?
  • 1 ***** the size of files you need for taking the backup. Files having graphics, sound and videos occupy more space than a simple text file.
    2 Plan the future requirements and consider the space needed accordingly.
    3 Choose an external drive of 20 GB or above to store huge data backups.
    4 Get an external hard drive and connecting cables to attach the drive to your computer.
    5 Select the data you want for backup. Organize the data into folders and sub-folders for easy find. Financial data, digital photos and music can form priority data for backup.
    6 Connect the drive to your computer. Use the drag and drop options for taking the backup.
    7 Remove the drive after properly ejecting by right clicking on the task bar on the desktop.
    8 Keep the external drive away from the place where you have your computer when done. If your computer gets damaged due to any unforeseen reason, you will have your entire data safe in the external hard drive. It minimizes the risk of data loss.
  • 0helpful
    Iomga eGo drive data back-up for Vista need transfer to Windows 7
    try to connect it to another computer that runs vista, reformatting is never a good thing. the portable hould be read on any other computer, but if you connect to another computer that have vista take it off and keep it on the other computer for a little (like someone elses computer) and put it back on to the computer with windows 7, reformat it and try to put our stuff back on then try again.
    2answers
    My external hard drive does not work on windows xp
    You might need to initalize it in XP and then assign a drive letter.
    108helpful
    2answers
    IOMEGA eGo portable hard drive won't copy files from mac
    Format your hardrive for Mac OS:
    Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
    Top Iomega Computers & Internet Experts
     Grubhead
    Grubhead
    Grand Canyon Tech
    Grand Canyon Tech
    Jerry Naidoo
    Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
