Coby MP-610  MP3 Player Logo
Anonymous Posted on Dec 25, 2009
Played in car once. Then plugged in to computer. Now all it says coby on the screen when turned on or plugged in computer. Device manager will not reconize . When not plugged in to computer and turned on it flashs coby then shuts off?????????
Anonymous
Level 1:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Jan 06, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
5
Helped
1060
Points
5
I threw the piece of cr????p away. It was junk. THX
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Dec 26, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
1254
Points
7
Same problem, only i didnt paly it in car, just around the house for a few min. System , device manager sees it as Other USB device with yellow error icon, so doesnt recognize it, even though 20min before i was moving songs onto it np from same computer. piece of ****
Hi i have windows 7 and i have mp301-mp315 coby when i plugged it in the computer a screen comes up but theres no coby media manager so where do i go to download it
All you have to do is download Windows Media Player (if you dont already have it) and connect the device. You will be prompted to sinc the device to WMP and you can add music etc without having the actual Coby CD. I REALLY hope this helps!
5helpful
2answers
How do you put a video on the Coby MP620 [4 GB] MP3 PLAYER
You can put a video on the device using "Coby Media Manager". To install it:
1. Plug your device into the computer
2. When the Autoplay menu appears, select "Open Folder to View". If no Autoplay menu appears, then look for the device in My Computer.
3. Launch the "coby-cometlite.exe" file and follow the setup instructions.
4. Now you should be able to use "Coby Media Manager" to automatically convert and transfer videos to the device,
1helpful
When I plug in my mp3, i cant sync because wmp doesnt recognize the mp3 at all. I was trying to find software or driver download to help fix. please help!
Hi, Looking for Drivers.
In order to download the right driver for a Coby MP3 player, you'll need to go to the Coby website support page where you can download software drivers (See Resources). To find the driver you need, you first need to identify which device you're using. Select "MP3 & Portable" under where it says "Select a Product" on the first box on the left. In the second box, it will be "MP3 & MP4 players." The final box lists all of the MP3 and MP4 players that Coby produces. You'll need to find your MP3 player in this list. The designation will be letters and number such as "Mp200". It should be listed on the box. Once your MP3 player is selected, clicking on the "Submit" button at the bottom will cause the text "Available Downloads for Mp200" (or whatever your MP3 player is called) to appear towards the bottom of the screen. Underneath, there should be a link for "Driver," if there is one available for your player. Clicking on that will allow you to download it.
Installation
If you click "OK" on the download screen, your driver should install. It will likely be in a ".zip" format, which means another program is needed to "unzip" the file so that you can install it. An example of such a program is WinRAR (See Resources). This program needs to be installed first, before it can be used to unzip your driver file. After you've downloaded the program, opening the installation file will begin the installation process. Choose a directory for where the program will be installed. After installation is complete, you can go back to the ".zip" driver file. Double-clicking on the file will bring up a new window. You can now drag your driver files from inside the .zip folder to any folder on your computer that you wish. There will be a file marked "Setup" among the unzipped folders. Opening this file should allow you to install the drivers you need on your computer.
Also Coby mp3 player not recognized by the computer.
Why is my Coby player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Coby mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Coby mp3 player can connect to your computer in MSC or MTP mode. Exceptions are Coby mp3 player Connect and Coby mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for Coby Players when used with Windows OS.
The Coby player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope that helped..
3helpful
My coby m600-4g mp3 player is connected to my computer through a usb port how ever my computer is not picking up the device. How do i get my computer to recognize the device as removable media?
You can install Coby Media Manager from the manufacturer.
Go to cobyusa.com
Select Support
Select the download Media Manager fix for MP822
Follow up the installation of Coby Media Manager for the operating system on your computer.
After the installation, run Coby Media Manager.
In Coby Media Manager, In the page top select: Tools > Device Manager...
From the Devices list select the matching MP600 AC or AL version.
Add >>
Select OK to setup the matching player as Favorite device.
In the Device Manager under Configure... or Device Configuration you
can choose between manual or automatic setup for synchronization
and the output file format can be changed.
Does not charge or play,read on computor
In order for the Coby to charge while connected to the computer or other charger, the Coby must be OFF before being connected to the computer. Check the following questions....
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and photo folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging in the battery area - upper right hand corner.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge with the player OFF.
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Go to the DEVICE TAB
2. CLICK on EJECT Button in lower right hand corner.
3. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
4. The second pop-up screen will tell you "The device can now be safely removed from the system."
5. The Coby will now show "Please Wait..."
6. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Let it run on music until it turns itself off. Recharge as above.
Hope this helps.
Not sure if player is charging
QUESTION ONE:
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
QUESTION FOUR:
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
e. You will see a USB connector icon on the player screen and the player charging.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
Hope this helps.
My Coby mp3 player won't connect to my computer
QUESTION ONE:
QUESTION TWO:
QUESTION THREE:
QUESTION FOUR:
c. Make sure the player is TURNED OFF ! ! !
e. You will see a USB connector icon on the player screen and the player battery charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the player turned OFF connected to the computer.
IT WILL NOT CHARGE WITH A COMPUTER UNLESS IT IS TURNED OFF WHEN YOU CONNECT IT.
(Found HERE if you have had to format the player)
Hope this helps
I have a coby mp-610 and I just took it out of the box and plugged it in to my computer. Nothing comes on, nothing. I've hit the reset button. I've turned it off and on. It doesn't even show it's charging....
COBY PLAYER MUST BE TURNED OFF WHEN BEING ATTACHED TO A COMPUTER...
QUESTION ONE:
QUESTION TWO:
QUESTION THREE:
e. Let your computer recognize it.
f. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the PLAYER OFF the COMPUTER ON.
f. Use the Coby Manager to disconnect the player (Found HERE If you've lost your copy on the player)
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter horizontally as the battery is wearing down.
Hope this helps
1helpful
Installation
If you have deleted the program from your computer, you should be able to plug the Coby player (TURNED OFF) to the computer and re-install it.
If Coby Manager program is no longer on the Coby player (If you re-formatted the player), you can get a copy of the MANAGER here:
Don't let it throw you that it says it's for the MP822 - it also works great for the MP610
1. Install Coby Media Manager from download
2. Open Media Manager
3. Plug your COBY player (THAT IS TURNED OFF) into the USB port - it will show up in the "DEVICE" tab
2answers
How to i download songs from my music to player
open my music
and my computer
when in my comp... open colby file 4 ur player open music folder on player then drag ur music from :my music to you player
hope this helped
Top Coby Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
