Try these procedures.
SOURCE: Lens Error
first of all the manual is available on this site, in case you'll need it in the future. the manual says that if you have a "lense error" message it means the lense is obstructed, i'm guessing against it in your case, but its worth while checking to see if theres nothing jammed in its track. it's actually a known, and common problem with these small casios. i heard that a quick fix is that when it happens the camera battery has to be removed, and that should clear it, but the problem can also return, and after a while that trick won't do the trick any more. if you want to have it fixed while still in warranty don't wait to see if any of the common "blow air into the..." or "use some epoxy" fixes help you, you can try all that later. good luck
SOURCE: Lens Error
Firmware doesn't solve lens errors. that can only be solved by sending into repairs. Give them a call at 800-706-2534 and then keep choosing option 1.
SOURCE: Casio Ex-z55 Lens cover not closing and lens does not operate
Buy the next camera- at 3 years old no economic repair will be feasible- but you could play with it some I guess
SOURCE: My Lens wont retract on my exilm zoom ex-z60
If it is under warranty Casio can fix it for free. other wise you end up paying the labor/parts. Can become very costly. I suggest open the case and replace the plastic housing that hosts the saw wheels. Should fix the problem
SOURCE: Casio Exilim EX-S880 won't turn on, lens clicks
mine is doing the same exact thing. please post again if you find out the problem or how to fix it.
