I had the same problem with my oven i think its a contact that conects to the bottom element the top one will work and olny go on broil cuz thats the olny time it comes on
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
hello there Usually, when an oven won't heat up or bake, it's because the
bake element is burned out. The bake element is the black, pencil-
thick tube at the bottom of the oven. When the oven heats, the element
glows red. This element has an expected life-span of several years. It
may last for only one; it may last for many more. When the element burns
out, you need to replace it.Now if the oven It bakes poorlyHere are two instances of when food "bakes
poorly:"When the food you're baking is done on top but not on
the bottom--or when baking just takes far too long to finish--the bake
element may be burned out. You may get fooled into thinking it's working,
because the oven is hot inside. But many electric ovens use the broil
element, too, during the preheat and bake cycles. So the food may be
getting heated only by the broil element, which causes poor baking
results. If the bake element is burned out, replacing it
should solve the problem. Otherwise, you need to further troubleshoot
the oven's electrical system to locate the defective wire or component.When the temperature is consistent but too high or too
low, it could be one of several different things. First check to see if
the thermostat sensing bulb has come loose from its holder. It could be
lying on the floor of the oven or resting on the heating element. This
would cause the oven to not heat correctly.If the thermostat bulb is not dislodged, it's likely
that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor
to monitor oven temperature. To solve temperature problems for these
models, you may need to replace the sensor. On some digital-display
models, you can calibrate the temperature using the key pad. See your
operator's manual for details. Ovens without a digital display often use a
mechanical system for controlling temperature. On many of these units,
you can remove the thermostat knob and adjust the knob itself to more
accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the
back of it with a small calibration plate, you can loosen the screw,
adjust the plate, then tighten the screw again. If the knob isn't
adjustable, and the oven temperature is off by more than 30 to 40
degrees, you need to replace the thermostat to solve the problem Hope thisis very helpful for you Best regards Michael .
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
I just found out my baking oven doesn't work and I hear the fan for the convection roast, but no heat. I had the appliance man out and he said that I need a relay board! Big bucks and they don't make this model anymore. Moreover, the microwave and warming drawer work fine. This is ridiculous!
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
I was wrong (I think). the baking element probably was burnt out as the repairman said. He replaced it and I thought selfclean still wasn't working. In fact, I think I just had to give the self-clean function more time. Also, I was judging by smell. We have become used to a bad odor during self clean which was missing when it was broken and still missing after the repair. Bottom line, the oven was clean after the baking element was replaced, sans smell.
