Tip & How-To about Welding Tools
Test tip is it working My model dohicky is not working.
Welding Tools Logo
3answers
1996 nissan sentra ac/heater switch works only on high. need help
I had the same prblem. There is a relay next to the heater blower that needs to be replaced.
GE spacemaker xl1800 and Pop tarts bad mix
it sound to me as if the high voltage diode is shorted. It could be inside the capacitor or out board the cap. The capactor could also be short but this is a rarity. Diodes are a cheep item . repace it and if it don't work its probably the magnatro. good luck.
Newer Kenmore washing machine doesn't spin in spin cycle
motor coupling broke ..this id dohicky between motor and gearcase or worse case gearcase suspect coupler first
more than likely the fuse has blown onthe magnatron it is the button looking thing on the magnatron with two wires. there are 2 of these one is on the magnatron the other is above the heat box test these for open. if open replace. if good then replace the magnatron.
Top Welding Tools Experts
ADMIN Andrew
ADMIN Andrew
littlewheel
Are you a Welding Tool Expert? Answer questions, earn points and help others
