Could be the fuse inside the microwave is blown. You will need to unplug the microwave and remove the front control panel. Inisde the microwave housing you will need to trace the electrical wire coming into the unit. Usually you will find the in-line fuse located on the black power wire. You can pull the connectors off the fuse and test it with a continuity tester. If the fuse is blown replace it but make sure you use the same amp rated fuse as you removed. If the fuse blows again then there is an electrical short somewhere in the microwave.
