Microsoft Windows Server Standard 2003 for PC Logo
Posted on Jan 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Abnormal Shutdown of windows 2003 standard
My system is installed WinXP earlier after that i tried to install windows 2000 professional which is not installed. Later Win 2003 server standard edition is installed. Now i am getting 3 options in boot screen i.e WinXP,Win2003 and Windows(for win2000). Windows XP is working fine. But when i logged in windows 2003 successfully logging. But, within 2-3 minutes it is automatically prompting for shut down with a message "your current session is closing with status code 128 due to problem with d:/windows/system32/isass.exe"
A
Anonymous
Anonymous
Level 2:
  • Expert 118 Answers
  • Posted on Jan 30, 2008
Anonymous
Expert
Level 2:
Answers
118
Questions
Helped
81214
Points
186
First, it is LSASS.EXE, Not ISASS.EXE.
You either have a variant of the W32.Sasser Worm, W32.Bobax, W32.Korgo, W32.Kibuv,
Hacktool.LsassSba,
Bloodhound.Exploit.8, Hacktool.THCIISLame or W32.Cycle worm.
There may also be some new worms that have not been identified as of yet that may
cause this shutdown.
Anonymous
Level 3:
Genius:
  • Master 1,067 Answers
  • Posted on Jan 26, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1067
Questions
0
Helped
419552
Points
2624
Y cuse its sharing isssas to 1st off way to maby boots 2 max os on hard drive unless u want to fail soon do all your updates
I tried to reformat my computer using windows xp prof service pack 2,completed the set up up to the installation of devices such as keyboard and mouse. but as installing networks reached about 35 percent,...
I sugest you get a new Windows XP SP2/SP3 CD/DVD for the instalation. It may be that the installation media you are using has problems. Another option would be to retry the installation with another CD/DVD Drive and see if the installation will complete. You can also use WinToFlash utility(www.wintoflash.sourceforge.net) to create a bootable USB drive with WinXP and install from it. Hope this solution helps.
In my laptop windows-XP was installed. then i installed windows-7. then i installed linux Red Hat. die to some problem of internet connectivity, i had to replace redhat by fedora. after successful...
NTLDR means ............New Technology Loader ...........
this is one of the most crucial part of the Windows OS, this specific component looks for the loader of NT(Windows OS) which loads the required OS files of WinXP(earlier it was called WinNT)...the naming legacy is still being followed though the OS has changed from Win95, 98, NT, 2000, XP, Vista, Win7....
The only way u can get back this is by re-formating the drive using the WinXP disk....more info ...click the link
http://en.wikipedia.org/wiki/NTLDR
2answers
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Abnormal shutdown
Ok, we are presenting a corrupted window and you reformat your Pc.
Back up you software and any other applicaiton.
1 Put you windows disk in and just after the logo appear depress f9 and answer yes to boot from cd. Follow the onscreen instructions to format hard disk and install windows/
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Computer software
You may want to run Word through maintence mode to see what is going on here, if it finds any issues it will attempt to repair it.
To do this:
1. Quit all Office programs. 2. Use one of the following procedures: • In Windows XP or Windows Server 2003, click Start, and then click Control Panel.
• In Windows 2000, click Start, point to Settings, and then click Control Panel. 3. Open Add or Remove Programs. 4. Click Change or Remove Programs, click Microsoft Office 2003 (Microsoft Office Word 2003), or the version of Office or Word that you have in the Currently installed programs list, and then click Change. 5. Click Repair or Repair Word (Repair Office), and then click Continue or Next. 6. In Word 2003 and in earlier versions of Word, click Detect and Repair errors in my Word installation or click Detect and Repair errors in my Office installation. Then, click to select the Restore my Start Menu Shortcuts check box, and then click Install.
2answers
Windows Server 2003 - How can I install Services remotely ?
In my opinion, using Windows Password Reset Software or free Ophcrack is the best method to reset Windows server 2008 password.
Windows Password Reset Software is such software that you can reset forgotten Windows password for Windows 7/XP/Vista by burned CD/DVD/USB. It is professionally designed to reset lost password with less time-consuming and 100% recovery guaranteed. Also it can reset windows password for Windows Server 2008/2003/2000.
If you want to get more information about Ophcrack, please login Ophcrack Official Website.
4answers
Microsoft Office Trial Version and Upgrade
I bought an upgrade version and it doesn't work. What should I do?
First, please confirm you meet the qualifying criteria for an upgrade purchase. To qualify for an upgrade you must have a valid license for one of the following products: Office Standard Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Office 2000-2007 (any program or suite), Office XP (any suite) Office Small Business Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Microsoft Office 2000-2007 (any program or suite), Microsoft OfficeXP (any suite) Office Professional Microsoft® Works 6.0-10; Works Suite 2000 –2007; Any Microsoft Office 2000-2007 (any program or suite), Microsoft Office XP (any suite) Project Professional Microsoft® Office Project Professional 2000-2003; Project Standard 2000-2007 Visio Professional Microsoft® Office Visio® Professional 2000-2003; Microsoft Office Visio Standard 2000-2007 Visio Standard Microsoft® Office Visio® Standard 2000-2003; Microsoft® Office Visio® Professional 2000-2003 Live Groove Microsoft® Office Live Groove® 2003; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite) Publisher Microsoft® Office Publisher 2000-2003; Microsoft Publisher Deluxe 2000; Microsoft Publisher with Digital Imaging 2003; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite) Small Business Accounting/Office Accounting Professional Microsoft® Office Small Business Accounting®2006; Microsoft Works 6.0-10; Works Suite 2000 – 2007; Microsoft Office 2000–2007 (any suite), Microsoft Office XP (any suite)
Found here:
http://us20.trymicrosoftoffice.com/faq.aspx?culture=en-US
4answers
Problem istalling windows 2000 professional on a pc with intel d945gcnl motherboard
try to make bios settings default and make a proper installation
The bios in this system is not fully ACPI compliant. Please contact your system vendor for an updated bios. If you are unable to obtain an updated bios or the latest bios supplied by your vendor is not ACPI compliant, you can turn off ACPI mode during text mode setup. To do this, simply press the F7 key when you are prompted to install storage drivers. The system will not notify you that the F7 key was pressed - it will silently disable ACPI and allow you to continue your installation."
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
