Question about Panasonic KX-T7730 Corded Phone
All voice mail is BUSY
How do I get in to voicemail if the system thinks the lines are busy?
    Novelist:
  • 201 Answers
You may be having a problem with your voice mail or phone system. Try turning the power off on the phone system and if the voice mail is an external part power that down as well. That would reset any locked up ports or lines. It will also disconnect any calls in progress.
If that does not solve the problem, try and figure out which phone system and voice mail system you have. The phone you have can work on a few different Panasonic systems.
Posted on Jan 28, 2008
Anonymous
SOURCE:
Mitel 4025 voicemail never picks up
Before voice mail will answer, the phone has to be programmed to forward to the voice mail pilot number on a busy and no-answer condition. Example, if your voice mail system is on extn 555 then program the phone to roll over busy/no answer to ext 555. (there will need to be a companion mailbox on the voice mail system that matches your extension). Hope this helps.
Apr 08, 2014 | Mitel Superset 420 Corded Phone
PHONE WILL NOT GO TO VOICEMAIL
The phone has to be programmed to roll over on a busy and no answer condition to go to voice mail. (Call-Forward Busy/No-Answer to the voice mail extension. Hope this helps
Mar 18, 2014 | Mitel Superset 4025 Corded Phone...
Need new voicemail within office
Depending on your voice mail system, It can be handled using a different table for the new companies phone line and use different greetings for the four time slots.
Apr 30, 2013 | NorStar M7324 Telephone
My phone keeps sending everything to voice mail, but i want it to just go to regular answering machine, how do i change it? The red light at the bottom next to voice mail is on. I've looked through the...
You'll need to find out from your phone service provider how to disable or change the settings on your voice mail. The service is part of your phone line and has nothing to do with the phone, so it's not covered in the manual. Normally the phone service provider gives you a set of instructions (or provides them on their website) explaining how to use the features on your line.
You typically enter "star codes" (*72, for instance) to enable a feature or change its settings. Voicemail usually has two modes: "busy", where it will pick up a message if your line is in use, or "no answer", where the voicemail picks up after a set number of rings. You would want to choose "busy" so that your home answering machine will take the call when you aren't on the phone, and voicemail only kicks in if someone else calls while the line is already in use.
Contact your service provider and they should be able to tell you the magic codes for your system.
Feb 27, 2011 | AT&T DECT 6.0 Cordless Phone System with...
We have 2 lines in our office. When both lines are in use someone calling in gets a busy signal. How can I set up Norstar Talk Flash so incoming calls can go to voicemail?
Order a 3rd line or order Central Office voice mail. If you have 2 calling paths to your premise, that's all you get.
There are other ways around this, like Call Forward Busy to a voice mail only line you control, but it's pretty much the same priciple as CO Voice Mail. Depending on how well you shop, $10 or less gets you the service.
Carl
Dec 16, 2009 | NorStar Lands Phones
Voice mail light does not come on when we have new voice mail.
Partner System doesnt have light notification feature if voicemail left on carrier site. I suggest you purchase small voicemail (4 mailboxes) for about $250 with installation and cancell your carrier voicemail service. You will be able to see new message light, also you can access your mailboxes remotely. It will pay for itself if carrier services cancelled within 7 or 8 month. If interested contact me vkagan at aaa-avad dot com. We are located in NY.
May 07, 2009 | Avaya Corded Phone avaparp18d
"flash busy" message when trying to retrieve voicemail messages
It is telling you that the voice mail ports are busy and can not take another call in to the voice mail system. If the port the does not clear up after a min or two then reset the voice mail system . Unplug the power cord from the wall and let it set for a min , then plug it back in and wait about 5 min for the system to come back up , that should free up the ports .
Apr 16, 2009 | Lands Phones
DND causing line to go busy when on call for new incoming callers
Please contact your local NEC dealer and have them program the phone to go to voicemail when in DND or when Busy
Mar 20, 2009 | NEC-1090021 DSX 34-Button Backlit Display...
Call Waiting
THere are two answers to you question, depending on certain options and conditions.
First, where is the voice mail and where is the call waiting coming from?
1. If Voice Mail (VM) is located in the central office and you have a destination for call forward BUSY/NO ANSWER it will go to CO VM.
2. If Voice Mail on premise (Partner Mail), and you have CF BUSY/NO ANSWER set on your phone, it will go to voice mail....IF the call waiting is coming from another line. The CF and ring count is set in Partner system programming.
3. If you have call waiting coming on the same phone line and don't have CO VM, then you have no voice mail.
My CO codes for VM are 72# for Call Forwarding and *92 for CF Busy.
As Always, YMMV
Carl
Sep 14, 2008 | Avaya Partner 34B Corded Phone
Panasonic KX-T7730 Corded Phone Logo
156 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
