I have seen at least three codes on this unit.
1)pl
2)do
3)nf
And sometimes the door will not latch, causing the unit to not wash.
Any ideas ???
Hello & Welcome to FixYa
NF error in your Maytag is
displayed due to no fill condition, when the washer tries to fill but is unable
to nf is displayed. Please check the water inlet valve for any clogs and
obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any
other questions.
Kevin
ND error in your Maytag Front Load washer
indicates no drain issue. To start with check the drain hose for any clogs and
try cleaning it, then check restriction in drain pump assembly or loose wire at
the pump. NF error in your Maytag is displayed due to no fill
condition, when the washer tries to fill but is unable to, nf is displayed.
Please check the water inlet valve for any clogs and obstructions, you can also
clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
