Question about Konica Minolta DiMAGE A2 Digital Camera
Wont turn on, low battery image flashing. I have charged the batteries.
    Brigadier General:
  • 3,006 Answers
Then check the battery contacts inside the camera are clean.
If that fails then replace the batteries as they do not last forever. Genuine Minolta replacements maintain their performance far longer than cheap generic ones (which often claim to have a larger capacity), but genuines are very expensive and cheapos are, well... cheap, and will need replacing far more often.
Posted on Feb 11, 2010
  • chip brokaw Oct 22, 2011
    Are there any other solutions? I have a brand new fully charged high-end battery... used an eraser to clean the contacts on the camera... it still just flashes the low battery warning and wont turn on
Anonymous
SOURCE:
Hi. My vax blade won't charge. The battery icon keeps flashing red and White any ideas?
flashing red just says turn it off because the battery is getting low. i guess thats cos it wont charge. wait 1 hour for temperature to become normal. wash filters and wait 24hrs til they are dry.check and clean battery contacts. those are the things the manuals list to try.
Dec 14, 2017 | Icon Cameras
My huawei mercury phone wont power on or charge
y wont my mercury turn on it wont even showet chargeing how can i fix the problem.
May 20, 2012 | Huawei M886 Mercury CDMA Cell Phone
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have had a tevion mp4 player for over a year and when I turn it on the screen flashes the low battery symbol and then turns off. But I know that the battery is full power because I have had it on...
It sounds like the battery isn't holding its charge. Rechargeable batteries only have a certain life span dependent on how many times they are charged/discharged.
You should be able to get a replacement battery and change it yourself without too much effort.
May 12, 2011 | Audio Players & Recorders
NO IMAGE ON MY MONITOR WHEN ON.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 24, 2010 | Canon PowerShot A95 Digital Camera
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
My k800i wont turn on. just the infa red led flashes
when k800i is in battery low, infrared led will blink... try to charge your battery of buy another one.
Nov 16, 2008 | Sony Ericsson K800i Cellular Phone
Casio ex-s600
Hello Gery, Try with the new battery. Best regards, Arpad
Jan 10, 2007 | Casio Exilim EX-S600 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Konica Minolta DiMAGE A2 Digital Camera Logo
187 people viewed this question
Top Konica Minolta Cameras Experts
Ekse
 Larry
Larry
Pierre Laplante
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
