On your motherboard there are sata slots, usually there are two or four of them, Locate which is sata1, sata2, sata3 and sata4...
Connect them at sata2 and sata3, because sata1 is for the harddisk... The computer should automatically set things up right for you and also with the OS.
Hope this helps.
At bios settings choose auto detect for secondary master and secondary slave.
one burner must be master and the other one is slave jumper settings. all burners must be place at secondary drives.
Thank you I have found that the Two Writer that I Have are LG GSA-H6-2N do not have Jumpers there is only the data in put and power no other these are the only writers I have found that does not have the jumper setting for the master or slave
Regards Tangles
Have found that Sata DVD writers do not have jumpers
have set the bios and now find that can not do any thing with the two drives
On my mother board there are two sata slots these have sata HD's connected
The sata writers are connected via a addon board which has two sata slots and two IDE connection one has a hard drive connected
The computer finds all driver and writers
can not get the writers to read or write disc's
