My canon rebel xti lcd screen will not display when taking a shot, but the lcd will display a picture after the shot is taken and will show previous pictures
This model does not have a live view capability. To compose the shot you must use the viewfinder and then you can check the result on the lcd screen. This the norm on semi professional and professional DSLR's
I'm afraid you can't view the image on the rear screen before you take the shot. On cameras like these,( semi and professional DSLR's) this is the norm. You view and compose the shot through the viewfinder and then you can check the result and view all your shots on the lcd screen afterwards
The XTi and prior EOS models have not capability to see the live image to be shoot on the screen. Only the image after taken can see on the screen. Other images also using the view mode.
If you can't review the images, eve if the display is turned off, just after they are taken, maybe the "Review time" is set to "off". Go to settings, 3th tab, Review time and set the desired setting.
Had the same problem myself, I purchased a new lcd from ebay (user name: ProphotoSD). He has tons of factory LCD's, cost around 90$. Please note that if you cracked the clear cover above the lcd that is a separate piece however it wont effect the lcd working (this piece is also replaceable). Then I found a simple tutorial for disassembling the camera body on google. Took me like 25 min, very simple job, just need a very small phillips head screw driver. Hope this helps!
You have to set the camera to "Live View" mode. Check your manual for settings. BTW, it's usually a bad idea to use Live View mode unless the camera is on a tripod. With Live View you have to hold the camera out in front of you and it's much less steady.
Hi Janet;
On most DSLR cameras you cannot compose or shoot using the LCD screen. The ability to preview the image using the LCD is fairly new to SLR's, and is known as "live view" on most models. So, like yourAE1, you still need to compose using the eye-level finder, then review your effort on the LCD later.
"Live View", where you can see and compose your picture on the LCD, was not available on any digital SLR before 2007 (the Rebel XTi came out in late 2006). So you need to compose your picture using the optical viewfinder, take your picture, and the picture shows up on the LCD after you've taken it.
But it's still faster than having to wait until the film is developed. :-)
