Press the "Menu" button on the remote to reveal the on screen menu, then press the cursor up or down until the option labeled "Features" is highlighted. Once the features menu is highlighted, press the cursor up or down buttons until the phrase ''Smartlock'' is highlighted. Next, press the cursor right button until it shows the phrase ''access code;'' on the access code screen, press 0, 7, 1 and 1 again. When the phrase ''incorrect code'' appears, enter a ''new code'' by selecting a four number code of your choice; this code will be used to control all functions related to the Smartlock code feature.
hope this helps
John
NOTE: Before you proceed with the Factory Reset, enter a four-digit access code. The Factory Reset and
Parental Control always share the same access code. The default Parental Control code is 3355
NOTE: Parental Control setting can be reset by doing factory reset
If you ar unable to do this proceedings, do the unlock method used for Philips, and your TVs kit is of Philips.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
