Internet channel my internet channel ran perfectly when i first used it but now when i use it it says it cannot connect to the internet but after a minute it says i have a working network connection but it is really slow and takes forever to load one page help!
How many 'bars' are showing on wi-fi signal strength indicator (presuming you are using wi-fi for internet access)? If the signal strength is low, you could be losing connections that way, or there might be interference on the wi-fi channel that the tablet is using. Try changing channels in your wi-fi setup and see if there is an improvement in the behavior.
Driverboost is known to cause damage and problems. In the future I recommend avoiding any programs that claim to update your drivers, boost your registry, or speed up your computer - they are all JUNK. and bad for your computer!
You might have a lot of neighbours using wifi, you get interference. Download "Inssider" and scan your area, usually this type of problem means several people on the same channel of wifi. to change your channel, log into your router (type 192.168.1.1 or 192.168.2.1 into internet explorer. then change the channel settings.
For the username and password put admin for username and leave the password blank
Now look for an option for the Wireless Settings and change the channel from usually channel 11 to channel 4 your laptop may now see it. Otherwise try another, channels available in the uk are 1-12, I think it's 1 to 11 in USA
Yes that's it.. try changing some wireless settings on your router like the ssid or wireless network name channel use channel 1, 6 or 11 then try to connect to your wireless network.
http://www.wiierror.com/wii-error-51000.php Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
just a few things that can be checked, firstly in the routers settings look at the transfer speed of the router(not the connection speed) and see if it's set at 108MBPS, if so your wireless network cards on your pc's may only be able to connect at a maximum speed of 54MBPS, unless you have the latest 108 or 125MBPS g type cards.
Secondly you should be able to check the wireless signal strength by the icon in your task bar or software you use, as if you have thick walls or objects in the line of the signal from router to pc's, the strength drops and can read low and therefore cause you to lose internet connection entirely.
You can also try changing the channel at which the router runs, normally this is channel 2, but trying channel 11, which is the farthest away from appliance interference may give you better results, but both router and network card channel numbers will have to be changed.
