I have a Sunpentown SP-3000 Hot Water Pot where the dispensing function does not work anymore. Where can I get a wiring diagram or how can I troubleshoot it?
Http://www.eserviceinfo.com/download.php?fileid=30158
Basically all eletric hot water pots are the same just like frig/stove.
pdf with wiring and parts.
Enjoy.
Good Afternoon friend, thank you for your post!
I understand that your Electrolux washer is no longer dispensing softener. This could be due to a build-up inside of the dispenser. I would recommend to remove the dispenser and you can do that by pulling it all the way out and there is normally a tab on the left hand side to push down that will release the dispenser. Once you have the dispenser out you need to run it through some hot water this will help break up any build-up. If that does not work you can place some hot water in the dispenser with the machine on a hot wash cycle and that could also help. If you continue to experience issues I would recommend having a professional technician out to properly disassemble your washer. I hope this information is helpful to some degree. -Matt
