Question about Holmes Products Cool Mist HM3500 Humidifier
My Holmes HM3500 Humidifier is plugged in and full of water. Just replaced filter. Filter has soaked water all the way up to the top of filter. Both lights are lit, but fan is not turning on. I have tried changing both the moisture and fan levels. Help!
  • 3,230 Answers
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Post comments  for more help or information .........
Good Luck!!
Thanks
Posted on Dec 22, 2009
  • bstewart313 Dec 01, 2010
    This product is a HUMIDIFIER, not a DEHUMIDIFIER, so the advice you gave ALL-GURU will not work.... good try though
6ya staff
SOURCE:
Need manual for Holmes humidifier model HM-220. Don’t see replacement filter numbers on Amazon. Is there another that will work
For a manual, try Googling (holmes)(HM-220)(manual) without parens.
Fixya is unable to advise regarding filter interchangeability.
May 12, 2018 | Humidifiers
Sunbeam humidifier 3502
Tanks are no longer available. Search for used units on your local craigslist.com. This model was previously made by Holmes and tanks were the same on HM3500, HM3501. Search "Holmes humidifier" then search "sunbeam humidifier" on your local craigslist.org
most bigger towns will have one or two show up. Keep an eye out. People who move to a house (or install) a whole house humidifier sell their old units. We have two of the exact model and I bought a new in box 3501 from a Craigslist posting in September 2013!
Mar 13, 2014 | Sunbeam Humidifiers
How do i clean the fan blades on the holmes humidifier
I am assuming a lime buildup from evaporated water. Use vinegar or drip coffee maker cleaner.
Jun 14, 2009 | Holmes Products Cool Mist HM3500...
I can't remove the grill above the fan so I can clean the blades
I have a Holmes cool-mist One-Touch Humidifier, and you can't reach the blades to clean them, and you can't take the console apart. I finally decided to use two spray bottles and clean and them rinse the Humidifer while holding the console upside down and over a sink. The one bottle you could fill with any mild cleaner plus a lot of water to dilute the cleaner. Maybe dishwashing liquid (not the dishwasher stuff), or a little bit of ammonia, or rubbing alcohol, or vinegar. Spray that on the blades while the machine is upside down, and a lot of sooty dirt drips out. Then rinse with another spray bottle full of plain water. Leave the console upside down on a towel to drip-dry. This is also how you can clean silk flowers that collect dust.
Mar 07, 2009 | Holmes Products Cool Mist HM3500...
Humidifier doesn't stop
I had the same problem if you dissasemble the unit you will probably find a capacitor between two blue wires has blown out
Mar 30, 2008 | Holmes Products Cool Mist HM3500...
Iron/rust in water
You can use distilled water to fill your humidifier that would save your filters.
Or you can try soaking your filter in a 50-50 water and white vinegar solution to try and clean them to use again.
Good Luck.
Feb 24, 2008 | Holmes Products Cool Mist HM3500...
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Feb 10, 2008 | Honeywell QuietCare HCM-630 Humidifier
Holmes Products Cool Mist HM3500 Humidifier Logo
504 people viewed this question
Top Holmes Products Humidifiers Experts
Ekse
ray gallant
Katherine Guy
Level 1 Expert
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
