I have the same problem, I took off the back panel and noticed that the EOC (electronic oven control) board is blackened and most likley need to be replaced. My wife was cooking a pizza and she smelled a burning plastic smell, she looked in the oven and saw the pizza on fire and smoke bellowing from the control panel area. So i unplugged the oven and saw the circuit board did start on fire and fortunatly it went out before serious damage. No matter what you set the oven on the display shows it as being correct, but only the top element comes on and it is on HIGH!!!! DO NOT BUY FRIDGIDAIRE!!!!
Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
