Hi, I have a 4 month old Frigidaire Dryer model #FEQB2152FE0. It now displayes the error code "dr" on the display, beeps 3 times and will not start. I have cleaned all filters and unplugged the unit, but to no avail. Help?
Thanks, John
Try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
I had the same problem with my frigidaire dryer and I tried everything and called technicians for help. They wanted to charge me $90.00 just to walk in the door and thats before any work was done. If your dryer is under warrenty call the place where you purchased the dryer and have them come out. Don't mess with any of the solution posted on this site because it is a bad control board. If your dryer is working it won't be long before it stop completely. If your dryer is out of warrenty go the local appliance parts store and purchase a new control board. It will cost around $170.00 and you can replace it yourself. It will take you about 15 minutes and you only need a phillips headed screwdriver. Make sure you take the model number of the dryer when you go to purchase the control board.
I just ran the Function test sequence which is in the Dryer Tech Data Sheet (this sheet is inside the dryer at the lower right side) and after that the machine is working. I hope this can solve your problems too.
So I'm having the same problem and thank goodness I bought the extended warranty. I called customer service this morning and they told me it had something to do with the drain hose(go figure). I still can't get my washer to work so they are going to come out and fix it.
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
I don't believe so....it's a Frig/Eureeka model
dr flashes on my frigidaire front load dryer. No one can help us. I have called Frigidaire. You cant talk to anyone. It is always a computer talking. Press 1 for this 2 for this then it tells you to call another number. I called the place we bought it . HA HA they are dumber than a box of rocks.. We asked for some one to come out and fix the dryer. We still havent had any one call us to come out. We will never NEVER buy another product from Frigidaire.
My Frigidaire dryer model # GLEQ2152ES0 has the same dr error code. I tried the tech's solution and it didn't work. The door is shut correctly. Any other suggestions? Thanks.
I am having the same issue with the dr code shown on the digital display. It will not turn on with any setting other than 20 mins low heat. This code is not explained in the user manual
is that an affinty model drier
Dryer will not stop beeping
