SOURCE: cacelling forward
To remove forwarding, lift your handset, push the FWD/DND key and dial 0. Here is the quick manual for that model - http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
SOURCE: How do you turn off
It depends on the kind of telphonesystem and the kind of forwarding.
Generally the procedure is #code# where code is
21 for call forwarding unconditional
61 for call forwarding on no reply
67 for call forwarding when busy
On most mobile operators you can do #002# or ##002# to take the all in one go.
On some fixed (analog/PSTN/ISDN) lines you can use #001# to take them all inone go.
Some PABXes(officephones) also have call forwarding on precense (lunch, meeting. etc) and this is often turned off with #23#
SOURCE: Forwarding a busy phone
you'll need the programming template that goes over the phone keys if you're not familiar with programming...
feature **admin (use #s on dialpad)
type admin again
select #6 permissions
enter set (ext)# you want to forward
scroll down to "forward on busy" & select
you'll see "forward to" hit the "change" button
enter in the extension # you want it to go to when busy
then select to store
SOURCE: Forwarding phone
This is not a phone equipment service but rather a phone service provider service.
YOU CAN FORWARD but to do this you need to have this feature enabled by your phone service provider. Then, follow their instructions on how to enable and disable this feature based on your calling plan.
