Hi, i have an actiontec GT704-WG router, and my laptop connects to it through wireless. i've been using Emule but its extremely slow, so i figure i've got a low ID. Then I've turned on the UPNP, and changed the firewall setting. But i still cant pass the port test. so how can i get a highID? Thank you !!!!
SOURCE: Looking for recovery software for the GT704-wg.
http://opensource.actiontec.com/index.html
All your answers.
SOURCE: GT704-WG with Verizon firmware
I just flashed my verizon modem FT704-WG with the actiontec update upgrade301060gt704wg.img. I then selected "Obtain an IP Address through DHCP" and bam away we go... working better than verizons version.
SOURCE: Change low Id High ID using eMule
Where are you Santiago, and Emule is still having conflics with its scripts, just change to a another Source, I will pull itup later on tonight and see where the Problem is,...
Aloha
Kahuna
SOURCE: After several years of service, now my Actiontec
electronics like these usually have a reset button behind them, try it. If not, it could be a problem of age, since staying on 24/7 for years really wears electronics out.
SOURCE: I need a WEP code for an Actiontec GT704-WG.
You MUST re-set up the Router again, login with a browser, this time copy paste WEP/WAP code into a notepad document. for use on client (Wii) now after setting up the router, check the SSID, the NAME of the WiFi Connection. Save this in router. Then on the Wii, use that written down key, to put the key into the box, this will allow access.
http://www.actiontec.com/support/product_details.php?pid=40&typ=doc
Get your manual from link above, that will help you set it up.
