Question about HP DeskJet 5150 InkJet Printer
All lights flashing fast on HP 5150 - HP DeskJet 5150 InkJet Printer
  • 434 Answers
Sounds like your DeskJet 5150 needs to be restarted. Try:
1) Press <Power> button to turn the printer off, then press again to turn it back on
2) If problem persists, turn off the printer
3) Disconnect the power cord from the power source
4) Reconnect the power cord
5) Turn the printer on
Posted on Dec 21, 2009
2 Suggested Answers
6ya staff
SOURCE:
komguy
Craig Gillette
  • 2306 Answers
SOURCE: I have an HP deskjet 5150 printer. The light
The teardrop is the ink symbol, if you open the cover and press the ink button it will move to allow changing.
Posted on Sep 15, 2009
Testimonial: "thanks. It helped alot"
My hp deskjet 5150 printer won't print - the ink light is on (even though i know i have plenty) & the paper jam light is flashing (but there is no paper jam)
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device and if you dont have the drivers
HP PRINTER DRIVER PACKAGES
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=25523
hope this helps you
Sep 17, 2011 | HP DeskJet 5150 InkJet Printer
My 5150 hp printer want print yellow light starts flashing i changed the color cart. still want print
there must be a problem on the mechanical system specially the cartridge carrier open the cover and check for any breaks on the belts replace them if any.
Aug 19, 2010 | HP DeskJet 5150 InkJet Printer
Sep 15, 2009 | Office Equipment & Supplies
Dell Dimension 5150 automatically turns off
That flashing amber light is usually a sign the power supply is failed or is failing. I would suspect the power supply is the problem in yours. It is the better of the two problems connected with the flashing amber light..the other is motherboard is failing. Arrrr!
hope this helps (it takes a standard- oh say 350 watt 20-24 pin power supply unit.)
Hope an answer helps.
Please leave rating, thankyou
May 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Laptop won't turn on, battery and power lights keep blinking
Looks like you are having a no post situation, generally a failed motherboard. Replacement motherboards are available on Ebay for around $100
Apr 06, 2009 | Dell Inspiron 5150 Notebook
Multiple probs w/ HP 5150
Try `driverguide` on the net.
Update your printer driver, this should solve your problem.
Also check the printer lead is ok
Feb 02, 2009 | HP DeskJet 5150 InkJet Printer
Printer has all lights flashing
Remove all ink cartridges. Then unplug your printer and plug it in again
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 07, 2017 | HP DeskJet 5150 InkJet Printer
Question for printer hp 5150
Ink has leaked into the printer and messages say problems with colour/black ink cartridge. Would cleaning the ink out of the print solve problem and if so what solvent is best to use.
Graeme
Apr 21, 2008 | HP DeskJet 5150 InkJet Printer
Error message
cartridge short. chek bleck cartridge
Jan 12, 2008 | HP DeskJet 5150 InkJet Printer
HP DeskJet 5150 InkJet Printer Logo
485 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
