If your amo is a subwoofer amp yes you want a LPF. Low pass filters are capable of passing low frequency energy. As far as the impedance of your amp goes check with the manufacturer for proper the proper load. What speaker config do you have?
2 DVC 8 ohms in parallel (voice coils) then series (speakers) are 8 ohms
2 DVC 4 ohm - in parallel (voice coils) then series (speakers) are 4 ohms
DVC is dual voice coil
Impedence for parallel is (Z1^-1+Z2^-1)^-1 or 1/((1/Z1)+(1/Z2))
Use those to figure out parallel impedance, series you just add them together.
Most fan cooled amplifiers would be fine on its side provided the flow of air is not impeded. Unless it's been modified the probability of a wire falling into the blades is pretty small. Where you may want to be concerned is if it's a convection cooled amplifier which would depend heat rising away from heat producing components and their heat sinks. Placing this type of amp on its side could reduce the efficiency of its cooling capabilities possibly causing it to thermally shut down and/or shorten its lifespan.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
