Zanussi ZWF1430W Front Load Washer Logo
Posted on Jan 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zanussi ZWF1437W washing machine - wont start
Programme for synthetics, temperature 40degrees, 900 spin all selected and lighting up on panel. time of 1.16 is also displayed. The door is closed yet the light is not on and the start/pause button also wont light.
The washing programme wont start, the reset button when selected only displays error. Have tried: unplugging machine, emptying filter, checking door is closed properly and nothing is caught in door seal. Any more suggestions? HELP PLEASE!
  • 7 more comments
  • tazcork Jan 25, 2008
    the error displayed is ERR when any button is pressed...what does this mean
  • Anonymous Mar 09, 2008
    machine was just finishing a wash and the electricity went off so when the electricity came back on i put another wash on but when i tryed to start the wash it kept saying ERR . how do i fix this
  • Anonymous Mar 23, 2009
    power went off now it won't start it just beeps but no err message
  • Anonymous Mar 13, 2014
    Panasonic model na 147 vba wont start,door door symbel shows locked on display,error code also shown [E03],slight clicking noise from door but not all the time??
    Panasonic model NA 147 VBA,machine wont start,shown as door locked on display,slight clicking noise from door but not all the time,error code of [E03] on display??
  • Anonymous Mar 15, 2014
    Hotpoint Ultima Washing machine WMD9692 changed language and having tried to reset it to English have now lost all visible signs on the LED DISPLAY AND THE PAUSE BUTTON IS FLASHING
  • Anonymous Mar 19, 2014
    every attempt to start brings on the door and spin light and machine wont work
    THE MACHINE IS DISPLAYING UE ON THE DISPLAY SCREEN, WHILE NOT RESPONDING TO ANY BUTTON AND THE DOOR IS ALSO NOT OPENING
  • Anonymous Mar 30, 2014
    Stopped in middle of run and door wont open
Anonymous
Level 2:
  • Expert 96 Answers
  • Posted on Mar 07, 2008
Anonymous
Expert
Level 2:
Answers
96
Questions
Helped
53715
Points
176
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Re: Zanussi ZWF1437W After setting programme on machine and after about 30 secs programme is cancelled all lights go out and zero in display and beeps. I have cleaned out filter at bottom of machine twice...
Sounds like you have a heater element problem. If the element is at the back then you should be able to access it by removing the back plate and unscrewing the middle nut and pulling it out, may need to pry it out as it can be tight and fit the element. If there is no back plate then you will need to remove the entire back panel, do this by first removing the lid, then remove the 2 screws at the bottom middle and 2 at the top that hold the back panel, and then it should slide out. Hope this helps.
1helpful
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Washing curtians
Select a delicate or wool programme, this will give you a cool wash and a slow spin.
Zunussi zwf1437w Keeps stopping during programmes
This sounds like a drainage problem. First thing is to check the filter behind the flap on front of machine.
Please post back your findings for further assistance.
Thankyou for using Fixya.
2answers
Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
2answers
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Zanussi ZWF1437W Washing Machine Problem
My Zanussi is 5 years old it onn th whole works well not making over the odd noise but is often marking my clothes with splashes of light brown after washing, which dosn't come off even with stain remover .
What could this problem be.
RR
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
