A previous post suggested the oven temp sensor may need replaced but:
If the oven temp sensor is not working, would the temp light still work? (the light that goes out when the oven reaches temp), Mine goes out but the oven seems to keep getting hotter.
If the light goes out and oven still burns things, would that indicate a problem other than the temp sensor?
The temp indicator light goes on and off according to the temp selected.
The sensor referred to is part and parcel of the the thermostat, or temp selector
the fact the light goes on and off, shows that the thermostatt is working, but neccesserily at the correct temp.I maintain that the thermostat that controls the temp is faulty, and needs to be replaced.
Hi
This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
