Canon PowerShot A530 Digital Camera Logo
Posted on Dec 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When Turning on the Canon Power Shot A530 the
When Turning on my Canon Power Shot A530 camera it:
Beeps 5 times,
Displays "Lens error, restart camera"
Shuts off.
CameraR
Level 3:
  • Canon Master 4,738 Answers
  • Posted on Dec 21, 2009
CameraR
Canon Master
Level 3:
Answers
4738
Questions
Helped
1196055
Points
12483
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, or if repair costs close to the value of the camera, they're worth a try.
Canon Power shot A530 repeatedly displays "change
First make sure that you are using quality batteries, and not "super heavy duty". If so, some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please see this link for more info.
My lense cover is stuck in a half-way position (Canon Power Shot A530).
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
2helpful
It has a lens error. Everytime the camera is turned on it beeps and clicks constantly. It eventually shuts off after displaying "Lens error, restart camera." on the screen.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Lens problems
Try opening your camera, check the lens gear if its teeth are complete. If so, check if something stucks on it. Its much better to bring your camera to an authorized service center to re timing your lens track... ^_^
5helpful
3answers
A460 lens error, restart camera
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
Lens error
The following blog outlines some simple repair options for a lens error. They won't work for all cases, but they're worth a try:
2answers
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
