Blodgett (ZEPHAIREG-DOUB) Double Oven Logo
Posted on Dec 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i vent my gas oven for my deli. i bought it used and do not have proper venting instructions?
Anonymous
Level 2:
  • Expert 79 Answers
  • Posted on Dec 21, 2009
Anonymous
Expert
Level 2:
Answers
79
Questions
0
Helped
23504
Points
200
Contact your local municipality's Building Inspector for code and fire department requirements for commercial installations. There will be a permitting process and fee involved but at least the installation will be done properly and not void your insurance.
Oven (electric) has small particles that look rusted where the oven cavity is joined, on the roof of the oven. I can see that whatever is wedged into the join has warped the metal.
It sounds like there may be some corrosion or rust buildup in the oven. This can happen over time due to exposure to high heat and moisture. It's important to clean your oven regularly to prevent this buildup. You should also use an oven cleaner specifically designed for this purpose. If the rust has caused damage to the metal, it may be best to call a professional to fix it. It could also be caused by overheating or thermal expansion. It's also important to make sure that your oven is properly vented and that the venting system is clear, as this can contribute to rust and corrosion.
Jan 30, 2023 • Ovens
Why is hot air coming out of the top of my oven
If you have a gas range they will vent the heat from the oven out the top by the rear panel. If an electric they will generally vent through one of the rear burners. I am sure that this is normal.
Nov 10, 2013 • Ovens
My Maytag stove. I know it's normal to feel heat from the vent on the stove top when the oven is on. But the temp of the heat escaping is sooo much hotter than it used to be. Do I need a fix ? Model...
The heat from your vent should be a little lower than what the oven is set at. So I doubt if you have a problem but you might want to take some temperature measurements to see.
Sep 07, 2011 • Ovens
Have an old MC oven seems like suddenly there is no gas coming through ? I used in a day ago
check regulators, and valves, on the regulator pay close attention to it's vent, (usualy a small brass bolt with a hole in the top) many times these vents become clogged with grease and other sediment, the easy fix is to buy a new regulator, the right fix is to extract the vent system from the regulator and boil it out.
My gas range/oven emits a toxic smoke that burns our eyes WAY different than spilled food. The smoke comes out the right side vent rahter than the usual left side vent and only when we cook higher than...
When the oven gets dirty and you don't run the clean cycle, dirt builds up and burns away the hotter the oven gets. Run the clean cycle if you have a self clean mode on the oven. throw the metal burner and grates in the oven too. (no plastic) open a window because it will stink and it takes a few hours to run. If not, use oven cleaner then run the oven to the hottest temp for at least 1-2 hours to burn the old dirt out..
Good Luck, Bill
Jan 07, 2018 • Ovens
MY PILOT KEEPS BLOWING OUT BUT THERMOCOUPLE IS BRAND NEW I AM GETTING FRUSTRATED BECAUSE IT GOES OUT AND THEN I LIGHT IT AGAIN AND IT WORKS WHY DOES THIS KEEP HAPPENING.
There can be a number of things causing that...
Is the oven vented? If so then is there a good cap on the pipe?? is the vent pipe high enough above the roof line?
Is there a draft diverter at the back of the oven where the pipe hooks on? A direct connection can cause this...
Is there a vent hood in the room that the oven is in??? Is there enough makeup air, or is the vent blower pulling air back down the stack?
Is the main burners "pulling" the pilot flame away from the thermocouple?
Is the "hood" on the pilot flame adjusted properly to keep the flame on the thermocouple?
Is the thermocouple positioned in the flame properly?
Is the thermocouple correctly tighten into the gas valve?
These questions are what I would be looking for if I was troubleshooting that appliance...
heatman101
I cleaned over with self clean and it blows the thermostate. Is this normal on Kitchen aid wall mount ovens?
if u have unproper vent specs on unit it will blow. read instellation spect for proper vent specs
I need a bellissimo oven manual
I to have brought a house with this oven and I am sure i am not using it properly, how did you go with instructions. Roz
Mar 28, 2009 • Ovens
Top Blodgett Ovens Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
