I just took apart mine and found the same problem. Broil and range work fine but nothing when the bake function is used. I pulled the heating coil and it showed open (infinite resistance). This could well be your problem too. Pull out the drawer on the bottom and you'll see where the coil connects. Pull it and check resistance with an ohm meter. If it shows open, that's probably your problem. It was pretty easy to pull and shouldn't be too tough to reconnect either.
Hi
If the lower wont heat and the upper work fine then it is
the coil itself that is bad and should be replaced. Hope this helps...please
post back for further assistance.
Daniel
