SOURCE: Olympus SP550UZ photos saved on camera memory not card
In the Menu if you go to the option that says Setup and press ok there should be an option that says Backup. This should allow you to copy the images from the internal memory to your xD card.
SOURCE: Olympus 790SW 7.1 MP reads full 1GB memory card is full after 2 pictures
Suggestion is to format the memory card and permanently delete all of the images from it. The card should then be able to be reused and you can start taking images again. To format the card go to Menu - setup and press ok - go to format and press ok - go to yes and press Ok. This will clear the card and you are back in business.
SOURCE: Olympus 2G xd M card with pictures - error message "clean card" or format
Just had the same issue today. The Olympus Helpdesk told me that the fact I had printed one of the picture from the Xd card in directly inserting the card in the printer slot for Xd created the problem....
The guy from the Helpdesk strongly recommended to transfer the pictures from the camera to the computer exclusively using the USB cable of the camera.
In the end I have saved all my 505 pictures in using the Smart Recovery from PC Inspector but why the hell this problem only happens with Xd cards?
SOURCE: Write Protect error and I think all my pics dissapeared!
If you are using an SD card, it could be possible that the Write Protect tab (the yellow tab on the top right) is in the 'lock' position. Slide it back and try again. If this does not work, make sure you are using the card and not the internal memory to store images.
SOURCE: Olympus u790sw unable to view photos / download
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to Format- You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
