Samsung NV10 Digital Camera Logo
Posted on Jan 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung NV10 heeelp!Pleeease
Hi i have this samsung NV10 camera thats worked fine until now.it stops mid way,beeps 4 times and shuts off, i can still see the pictures but when it comes to the videos it only plays a couple seconds and then the screen goes black and it shuts off. What do i do???? i need my camera!
  • Anonymous Feb 27, 2008
    It lets me see the pictures in my gallery when in gallery mode but once I switch to take pictures, it beeps 4 times then it shuts off. Anything to fix this?
  • freddiepep Oct 16, 2008
    i have the same thing.
    i can still see the pics ect, but if i turn the power on, the screen stays black and it beeps 4 times then turns itself off, i need a solution that can be done quickly, cus i really need my camera by tomorrow :S and what is WD-10 or whatever it was :)
A
Anonymous
The lens is jammed.
This is a result of damage to the gear in the motor asssembly.
The gear teeth have been broken off & as a result the gears that drive the opening& closing of the barrel dont mesh together resulting in the jam and your 4 beeps!!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
495
Points
I HAVE THE SOLUTION
I had the exact same problem and now it works perfectly.
The lens assembly needs a little WD-40. Warning, DO NOT spray on the lens assembly itself. You do not want to get WD-40 on the glass part of the lens itelf. Here is how you do it:
1. Turn on the camera and let the mechanism project the lens out as best as possible. You may help it out with your finger-nail at front slowly pulling at the lens. Do not use force. If you can only get it half out, then that should be fine too. It will probably beep at you and turn off again. That's okay.
2. Take a sheet of paper and spray some WD-40 on the edge of the paper.
3. Gently apply the sprayed part of the paper around the lens between each of the lens cylinders (where it telescopes out.) You want to trickle tiny bits of WD-40 into the mechanism.
4. Turn on the camera and do step 1. again. It may now already work a little better now.
5. Do step 2, 3 and 4 again and maybe one more time until you have lubed up the mechanism well enough to the moving parts nice and slippery.
6. Use your good judgement. Turn on and off the camera until you notice that your camera lens mechanism no longer gets stuck.
I did this about a month ago with my NV10 and it still works like new.
Good Luck!
muga
Anonymous
Level 3:
  • Master 871 Answers
  • Posted on Jan 24, 2008
Anonymous
Master
Level 3:
Answers
871
Questions
5
Helped
364070
Points
2104
Hi
have you tried different types of batteries? just try the occasional lithium battery and if it still doesnt work, try alkaline battery.
i can say that the beep 4 times means that it has something to do with the power.
hope this helps.
1 Related Answer
Anonymous
  • Posted on Apr 18, 2009
SOURCE: Samsung NV10 heeelp!Pleeease
Not sure about the battery... that could be it and I haven't tried switching it out for a new one yet, but in the meantime I am getting around this problem my grabbing the lens with my fingers and "helping" come all the way out... just give it a little pull, a little encouragement and it will come all the way out... but the trick is that you have to do it right after you try to turn it on and before you get the beeps...
So if your lens is stuck out right now and the camera is powered off, then turn the camera on and then pull the lens out before you get the beeps... once you give it a little tug, the mechanics should take over and it will extend all the way... the LCD will come on and you'll be good to go...
Like I said, I'm having this problem too and my girlfriend suggested we change the battery... I guess that's possible, that the battery is not holding enough of a charge to push the lens all the way out... I'll investigate how much a new battery costs and then determine if I think its worth a try...
6helpful
Samsung nv10 digital camera, the lense is stuck in zoom position. if i turn on my camer i cant get it to close and then it shuts off
Hi! As a first course of action please remove the battery and press hold the power button for 10secs. while the battery is removed. Install the batter, turn it on and see how it goes.
2answers
Digital camera starts then shuts down
yeah its broken sorry mate
suggest a new camera
Dec 15, 2008 • Cameras
1helpful
Problem with camera
The lens is sticking, I had same problem, thought it was the battery. It kept doing 4 beeps and turning off, but the lens would be out.
Lightly lube the lens area with WD 40 worked, be real careful and don't use alot of it. My camera works fine now. I actually read the solution someone on this site, can't find it now, but wanted to post that it worked for me. I love the camera and was bummed it wasn't working. Works great now!
5helpful
6answers
1helpful
Samsung nv10 processing problem
I had the same problem too. It started after I let my friend borrow my memory stick. His camera was a canon and when he used it, his camera created a folder called canon on my memory stick and thus there were two folders where pictures could be saved. I guess my camera didn't know where to save them so it just kept saying processing forever. I deleted the folder called canon and its working perfectly now. So make sure that you only have the 100SSCAM folder in the DCIM folder and it should be fine. Hope this helps!
Samsung NV10 lens won't retract/Autofocus doesn't work
please check your manufacture warranty as my samsung nv10 comes with a 2 year warranty
8answers
Samsung NV10 - 4 bleeps on switching on then turns off
my camera started doing the same exact thing, did you ever get an answer?
4answers
I was able to contact the manufacturer who repaired my camera under warranty. They were wonderful to work with and my camera was only out of my hands for 10 days, out just before Thanksgiving and back just after! Amazing for a holiday time frame.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
