Question about Timex Watches
Airplane mini -dont know how to access battery
Airplane mini -dont know how to access battery area-did get clock part off plane -I dont know what type of plane it is - has struts from wings to body of plane
    New Friend:
Put a note on Facebook and suggestions - take it to a local jeweler, go to Wallmart where they have all kinds of batteries. So, I'll try the jeweler, and I have to find a wallmart - we are 14 miles from NYC - there must be one around here - so - not solved, but suggestions thanks anyway.adriana
Posted on Dec 21, 2009
  • misty hollins
    misty hollins Feb 22, 2019
    Did you ever figure it out? I am having the same problem.
6ya staff
SOURCE:
I need G-Force giant atomic clock instructions. There is no model number on the clock. I put in new batteries, and it sets to 1-1 month and day and 12:00 time.
See if these are the instructions..
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.lacrossetechnology.com/media/catalog/product/5/1/515-1316.pdf&ved=0ahUKEwi20reMi4jWAhUh24MKHcfpBeEQFggsMAI&usg=AFQjCNEsCBnwTraroE9N7qRdGqTzKjh3Fw
Sep 03, 2017 | The Watches
Were do I sauter the copper wires on quartz battery operated mini grandfather clock
I do not know. I also am not familiar with the process of "sauter". If you want to solder them then check the manual or look at one like it.
Dec 19, 2014 | Watches
Danbury clock 'things remembered'. How do I access the battery? I cannot figure out how to find the battery. The battery is dead after two years and I need to replace it. It is not obvious how to...
The things remembered clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jan 31, 2014 | Watches
The clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    How to change the battery in a CASIO CA53W-1 Watch with Calculator
    open up the watch. there is a small spring that could fall out. dont lose it. use a small pin to pull battery clip off. put new battery in, replace strap and pink plastic. short the tiny contact labeled AC with the + on the battery. check that the clock now operates. lastly, reassemble
    there is a spring inside that goes betweeen one of the contact holes. dont know which.
    Jun 03, 2010 | Casio Watches
    I have a Relic airplane clock and I do not know how to replace the battery, the number is RML0000040. On the bottom of the plane is Limited Edition and China Case
    It's not easy. You're probably better off brining it to the jeweler unless you already have the tools. You'll need a precision screwdriver set. Under the clock there's a tiny screw. Carefully remove that to pop the clock off the front of the plane -- don't strip it. Then get a standard flathead screwdriver to remove the cover behind the clock. Just turn it so that the tabs on the cover appear in the little openings around the edge. It should then fall out. If not, use a tiny screwdriver to remove it.
    Under there is the clock. Remove the plastic spacer. You'll see the tiny little battery, which is held in by a tiny metal arm. Move the arm and the spring behind the battery will pop it up a little. Use a tiny screwdriver to carefully remove the battery. The battery is SR626SW.
    Have fun putting it back together! Whoever designed this thing is on my s-list.
    Apr 16, 2010 | Watches
    I am looking for instructions on how to change the battery and how to set the time on a Fossil Limited Edition Airplane desk clock (# 54 on wings). Thanks!
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all Fossil watch manuals. Rate me, plz.
    Feb 16, 2010 | Fossil Watches
    Set time on Touch Screen Thermo Clock
    Just in case you didn't manage to set the time / date on your tocuh screen thermo clock, I'll try to help you from my experience (no available manual at the moment!).
    1. To set the time, touch the clock icon on the upper left corner;
    2. Keep touching the screen for longer than 5 seconds, on the hour area;
    3. Touch the hour area until you get what you want (if you prefer the 24 hour display style, touch repeatedly until you get the right hour without the AM / PM indicator next to it);
    4. Touch the clock icon again to start the clock;
    5. Repeat steps 1 to 4 to set up the minutes (the hour area will be replaced by the minutes area);
    6. To set the date, tocuh the calendar icon on the left hand side;
    7. Keep touching the screen for longer than 5 seconds, on the year area;
    8. Touch the year area until you get what you want;
    9. Touch the month area until you get what you want;
    10. Touch the day area until you get what you want;
    11. The screen will reverse to the time display after 5 seconds if no touch.
    12. The TEMP (temperature) area, if touched, is toggling between C and Fahrenheit degrees.
    P.S. I don't know if it is possible to set an earlier time / date, except touching. I mean, if 2009 is on the screen and you want 2007, you'll keep touching up to 2030 and then from 1901 up to 2007.
    Hope it helped.
    May 08, 2009 | Watches
    Stanley tape measure clock set time
    On the bottom of the stanley clock you will see a little area that you put a coin in and twist,it will pop open to the battery and setting knobs.
    Nov 03, 2008 | Watches
    Watches Logo
    628 people viewed this question
    Top Timex Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    MrFixitSTTL
    pacdave
    Are you a Timex Watch Expert? Answer questions, earn points and help others
