Posted on Dec 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My washing machine 205DAWN does not agitate - Office Equipment & Supplies
Jose Pino
Level 3:
  • Master 563 Answers
  • Posted on Dec 21, 2009
Jose Pino
Master
Level 3:
Answers
563
Questions
0
Helped
133174
Points
1604
The reasons why a washer may not agitate are:
- The motor is broken or a foreign object is jamming the motor.
- The Lid switch is not detecting the lid is closed so the machine doesn't agitate.
It's a good idea to check the user manual for warranty information.
How to remove the agitator of a top loading moffat washing machine model: MTAP1100F2WW
Here are the steps to remove the agitator from your Moffat top loading washing machine:
  1. Unplug the washing machine from the power outlet and turn off the water supply.
  2. Open the washing machine lid and remove any clothing or items inside.
  3. Locate the agitator in the center of the machine's tub. It should be a large plastic or metal component that rotates during the wash cycle.
  4. If your agitator has a fabric softener dispenser on top, remove it by pulling it straight up.
  5. Look for a locking mechanism at the bottom of the agitator. This is usually a plastic tab or lever that needs to be pressed down or pulled up to release the agitator.
  6. Use a flathead screwdriver or a similar tool to press down on the locking mechanism while pulling up on the agitator. This should release the agitator from the tub.
  7. If the agitator does not come off easily, you may need to use a bit more force. Try rocking it back and forth while pulling up on it to loosen it from the tub.
  8. Once the agitator is removed, inspect it for any signs of damage or wear. If it is damaged or worn, you may need to replace it.
  9. To reinstall the agitator, simply line it up with the center of the tub and press down firmly until it locks into place.
  10. Finally, replace the fabric softener dispenser if you removed it earlier and close the washing machine lid.
Note: The exact method for removing the agitator may vary slightly depending on the specific model of your Moffat washing machine. If you are unsure about any of these steps, refer to your machine's user manual or contact a professional technician for assistance.
My Maytag Heavy duty 4 speed select, 10 cycle washing machine agitates while in spin cycle why?
If your Maytag washing machine is agitating during the spin cycle, it could be due to a few different issues. Here are some possible causes:
  1. Defective Transmission: The transmission in the washing machine is responsible for shifting the agitator and the drum between the spin and agitation cycles. If the transmission is defective, it may not be able to engage or disengage the agitator properly, causing it to spin during the spin cycle.
  2. Worn Drive Belt: The drive belt connects the motor to the transmission and helps to control the speed and direction of the agitator and drum. If the belt is worn or damaged, it may not be able to properly control the agitator, causing it to spin during the spin cycle.
  3. Malfunctioning Clutch: The clutch in the washing machine helps to regulate the spin and agitation cycles. If the clutch is not functioning properly, it may not be able to disengage the agitator during the spin cycle, causing it to spin along with the drum.
  4. Faulty Timer: The timer controls the various cycles and functions of the washing machine, including the spin and agitation cycles. If the timer is faulty, it may not be able to properly sequence the cycles, causing the agitator to spin during the spin cycle.
It's best to have a professional technician inspect and diagnose the issue to determine the exact cause and the necessary repairs.
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Maytag Atlantis Model 8551AWW washing machine...fills up with water...then starts the agitation cycle and will agitate for about 1 minute...then shuts off...after about five minutes the agitation cycle...
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Washing machine agitates, but does not spin
my amana washing machine does not agitate, but it does spin
11helpful
3answers
k24674
ADMIN Andrew
ADMIN Andrew
