You can get the manual for model 41214 from my dropbox area:
http://dl.dropbox.com/u/54567653/husky_aircompressor_model_41214.pdf
BTW, if you find this manual helpful consider installing dropbox using this link (full disclosure -- I do get about 0.2 GB freespace from dropbox if you install using this link):
http://db.tt/vQycqXIW
Thanks,K
I can give you all the relevant data and specifications. I hope that is enough for you. Otherwise your going to have to go to Home Depot and try to get them to get or perhaps if you bought it from them copy one they have.
As for the Husky Tools web site it now redirects you to Home Depot.
Description:
1.5 Gallon Low Profile air Compressor. 1 Running HP, 135 Max PSI,
Oil Free. Portable Lightweight Design with onboard storage. 2.0 SCFM at
90 PSI, 3.0 SCFM at 40 PSI.Ideal for Inflation, Cleaning and Fastening.
13 piece accessory kit included.
Specs:
I have a large source to search for items like manuals and so far I have found only one Husky compressor manual. However I will keep looking. If I find it I will let you know. In the mean time if there is something you need to know more specific about you compressor please just ask and I'll get you an answer ASAP.
Hope this helps and Happy Holidays to you and yours.
Testimonial: "Thank you so much for responding. I am sure your information will do the trick. Thanks again the Happy Holidays!!!"
I have a little update. Husky air compressors are made by Nu Air USA Corp based in Shanghai China. I don't know how many of the Husky's are made by this company, but probably all. Home Depot seems to be the only retailers for this models. So if you want a manual for that exact model they are your best bet. I did manage to locate manual for another model. It is probably the same internals with a different exterior. the specs are almost identical. Just follow the link I provided below, It is in pdf format so you will need the free adobe reader to view it.
Hope this does it for you. But again if not please just ask.
Oh and one more thing, you can also try this contact number. It is listed as compressor support.
#1-866-242-4298
http://powertool.manualsonline.com/mdown...
Go to the Campbell Hausfeld website at http://www.chpower.com/ and under 'Service and Support' click on 'Manuals/Parts List'. Put your model number, WL6510, in the search box and you'll be presented with all the parts breakdowns and manuals for that series compressor. The first part of the serial number on your compressor is a date stamp so use that to determine which manual or parts list you need.
