Question about eMachines E19T5W 19" Monitor
Keeps switching on and off frequently. have to press the input button on the side to get the display back
    Problem Solver:
  • 15 Answers
EMachines are well known for having VERY POOR quality products. If it's turning on and off all the time, it really has to be defective, sorry. check www.mwave.com for great discounts on monitors, I buy from them all the time. Erick
Posted on Dec 20, 2009
6ya staff
SOURCE:
HOW DO I USE side buttons to get tohdmi1 and stay there, it keeps going back to the tv?
Hello Vicki Shaw,
My "side buttons" are on a big 8 yr old SAMSUNG...
(USA model (not a smart tv))... Look for your (input)
"SOURCE" button.
I can only "select" video sources that actually have
active VIDEO signals on them....
So ... just a guess here:
You will need to verify the HDMI1 source is active...
FROM your "side buttons" you will note that the
"SOURCE" button when tapped will display a
SOURCE... within a few seconds ... (if active)
Your set will start to display the ACTIVE MEDIA
(or the indiscriminate noise of the DIGITAL
"BROADCAST" input (again: still no smarts))...
Else mine will switch back to the next recognized
input (in my case a CCTV server).
Carnac the Magnificent
Mar 30, 2017 | Televison & Video
Grandchildren put in video now cant get signal back on tv
On you remote control look for INPUT or SOURCE, cycle though until you get it back. Very often it will be listed as the name of the cable or satellite source.
Jul 04, 2016 | DISH Network Televison & Video
How to set value 08 mode code 695 set value to 0
Hi
Please switch of the machine.
While holding buttons [0+8] down, switch the macine on, when [ad] appears in the display remove the fingers.
Now key in [695] and press the start button, when [1] appears in the display input [0] and then press the interupt button.
[Ad] will then reappear in the display, now input [971] and press the start button, make sure that value is [3] and then press the interupt button.
Switch off the machine and then switch back on to take it out of the test mode.
Those two codes will disable the machine checking for toner.
Apr 11, 2011 | Toshiba e-Studio163 Copier
How do i hook up my ps3 with tv through hdmi as it keeps goin to blue screen
  1. Connect the PS3 standard composite video connector (yellow RCA plug) to the TV composite input and switch the TV to that input. Leave the HDMI cable connected.
  2. Make sure the PS3 is off. Turn it on and hold the power button until you get two beeps (at least 5 seconds). The PS3 navigation screen should be shown on the TV. If not, switch the TV back to HDMI; the screen should be displayed at 480i resolution.
  3. Go to the settings menu. Select Display Settings, then Video Output Settings, then press the X button on your controller.
  4. The on-screen instruction should be "Select the type of input on your TV." Select HDMI, then press the '> (solid right triangle) button on your controller.
  5. You will be offered the choice of Automatic or Custom settings. Try Automatic first (if there is a problem at the end, start over and pick Custom the second time).
  6. Press the X button. You will get a screen asking you to confirm the changes. Press the X button again to confirm.
  7. You may get a screen asking for the resolution setting. IMPORTANT: if your TV's maximum resolution is 720p or lower, do not pick a higher resolution. The TV may not display properly or may not display at all (blue screen). Pick the highest resolution your TV can display.
  8. Confirm this by selecting "Yes" and pressing the X button.
  9. The settings list should now read Connector Type HDMI; Resolution Standard (NTSC); 480p; 720p; 1080p (if applicable). Press the X button to confirm.
  10. You may be offered a choice of audio outputs; you can use HDMI or something else, depending on your setup. Confirm the setting and press X one more time.
At this point, the PS3 should send its signal to the HDMI port following restart. If your TV has more than one HDMI input, make sure you select the one connected to the PS3.
Mar 12, 2011 | Televison & Video
I do not have a remote for my model LG 42lc50c and i cannot get to switch from AV2. Is there a way to do this without a remote?
The button that switches from AV2 is the "Input" button, on the lower right side of the TV. But keep in mind, another Audio/Video source needs to be plugged into another input (located on the back of the TV) in order for this to work. The TV has to recognize multiple input sources to switch between them.
Jan 25, 2011 | LG 42LC50C 42 in. LCD TV
How do I reset my maintenance required light on my 2009 Avalon?
SWITCH IGNITION ON WITH ENGINE OFF.PRESS SMALL ROUND BUTTON ON LOWER RIGHT OF THE SPEEDOMETER UNTIL IT DISPLAY ODOMETER.THEN TURN OFF IGNITION SWITCH OFF.PRESS AND HOLD SAME ROUND BUTTON LOWER RIGHT SPEEDOMETER TURN IGNITION TO ON WITH ENGINE OFF.CONTINUE TO HOLD BUTTON FOR AT LEAST 5 SECONDS UNTIL IT DISPLAY INDICATES 000000 AND MAINT REQUIRED LAMP WILL EXTINGUISH.RESETTING IS COMPLETE.
Oct 19, 2010 | 2008 Toyota Avalon
I have a new DELLS2209W Monitor. On occasion my
I want you to try something next time this happens, instead of rebooting the computer, just cut power to the monitor. Then switch it back on.
Does the screen come back up?
Comment back and let me know
Mike
Dec 19, 2009 | Dell Computers & Internet
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
I have a pioneer DEH-P3000
Hi nhmteam. I have the solution for you: 1. With your DEH-P3000 turned off, press your FUNCtion button. It's a tiny button towards the upper right of the faceplate. Hold it down until you "ALARM OFF" or "ALARM ON" on the display. Release the button. 2. Press the FUNCtion button again and you should see another feature. I don't remember how many features you need to cycle through, but keep releasing and pressing the FUNCtion button until you see "M-CD ON" on the display. If you miss it just keep going and eventually it will come back. 3. On the right side of your faceplate there is a button with 4 arrows. You will need to push the up or down arrow until the display reads "M-CD OFF". If your display already reads "M-CD OFF", kip to the next step. 4. Press and release the FUNCtion button again and you should see "AUX OFF" on the display. Again press the up or down arrow until the display reads "AUX ON". 5. Now, turn on your unit, then press the INPUT button until the display reads "AUX". You are now ready to use your iPod in the way you always did. Keep these instructions for the future since I believe every time you disconnect the unit from the battery the unit will reset itself and disable your iPod cord. Best regards - TomR
Aug 30, 2007 | Pioneer DEH-P3000 CD Player
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Open Questions:
eMachines E19T5W 19" Monitor Logo
253 people viewed this question
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
