No signal to monitor
Which motherboard replacement should I use for a HP pavillion M7160N system?
    Problem Solver:
  • 15 Answers
Me personally I would look on the motherbaord for the numbers and try to find an exact replacement on ebay. If that doesnt work out, take it in to a store or send me a picture of it and Ill give you a recommendation. The main problem you run into is that the HP cases are proprietary and only fit certain boards. - Erick
Posted on Dec 20, 2009
Testimonial: "Thanks for the feed back!!!"
6ya staff
SOURCE:
Why when turn on computer there is a sound signal from computer but the monitor has no picture but monitor is okey.
If the monitor works on a different PC, the problem may be your video graphics card. If it is a builtin graphics card, you can install a graphics card and disable the integrated one if there is an open slot on the motherboard.
Aug 23, 2014 | HP pavillion media center m8330f pc
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
I need a new motherboard for my hp pavillion f50.
You can find motherboard for most systems on EBay
http://shop.ebay.com/i.html?_nkw=HP+Motherboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Motherboards&_odkw=pavillion+motherboard&_osacat=0
That is a generic search for an HP motherboard. You will need to refine the search for the model of your tower (F50 is the model of the Monitor)
Dec 27, 2009 | HP Pavilion F50 17" Flat Panel LCD Monitor
Which motherboard to use in replacement of
Unless the motherboard is a late model motherboard, it maybe impossible to get a exact replacement. Your best bet is to try HP.
Motherboards and desktop cases have standard mounting holes, I would suggest you buy a late model motherboard that suit your requirements and mount it in your desktop case. There are a large range different manufacturers to choose from. My favorites are from Gigabyte and MSI.
Make sure the ATX power supply has adequate power output.
Dec 20, 2009 | HP Computers & Internet
Monitor says No input signal and going to sleep. Pc is on and running Vista. Hp w1907v monitor HP Pavillion slimline pc. Can you help please?
Try cleaning your RAM it should be the issue mostly 80%
You can check by rremoving the VGA cable if the system shows no signal mostly monitor should be fine
Nov 30, 2009 | HP w1907 LCD Monitor
HP PAVILLION DV9500 everything works except the monitor??
This question requires a techincal person to first, attach an external monitor to the laptop to see if there is video going to the external monitor? Then while the external monitor is hooked up he should run full diagnostics to see if the motherboard video adapter is fully functional? If it is? He has to open the laptop and trace to see if the plug from the motherboard to the monitor needs to be reseated. The worst case scenario is you will have to replace the motherboard.
Jul 25, 2009 | HP Pavillion dv9740us Notebook
HP pavillion dv9005 no display - works fine on external monitor
If the notebook's video card (which may be on the motherboard) is successfully displaying images on an external monitor it sounds more like a problem with the notebook display or its connections. Probably the motherboard is OK.
Jul 09, 2009 | HP Pavilion dv9000z Notebook
Monitor on HP Pavillion a656x---blew up the power supply--had an extra and installed it--when machine was turned back on--monitor displays "VIDEO CABLE CONNECTED?---what am I going to do----help!!!---
First thing I would do is try the monitor on another system to see if it's in the monitor or computer. Next would be to fire it up and see if you hear a beep from the motherboard. Most consumer pc's will come with a small speaker that sounds on startup. If you don't hear this beep it could be indicitave of a fried motherboard.
But it sounds to me like your video card or onboard video was messed up when the power supply conked out. If it's onboard video you may be able to switch to a video card. If it's a video card you may need to replace it.
Also check to make sure there are no loose wires, that your video card is seated firmly, and that your connectors are all snug. If none of this works then you're most likely looking at a motherboard replacement.
Apr 19, 2009 | Computers & Internet
I need to get a hold of the diagram for hp media center pc m7160n
Not trying to give you a flippant answer, but what sort of diagram?
Troubleshooting diagram? Motherboard diagram? Diagram of how the cables connect inside?
Hmmm, let me see,
1.Troubleshooting and System Recovery Guide,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=470506&
2. gtabblt.gif Motherboard specifications table gtabblt.gif Motherboard layout and photos gtabblt.gif Clearing the CMOS settings gtabblt.gif Clearing the password settings
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00379422&lc=en&dlc=en&cc=us&product=470506&lang=en
3.HP.com/Support and the main page for the HP Media Center m7160n Desktop PC,
http://h10025.www1.hp.com/ewfrf/wc/product?product=470506&lc=en&cc=us&dlc=en&submit.y=8&submit.x=6&lang=en&cc=us
Apr 11, 2009 | HP Media Center Photosmart PC (M7160N) PC...
At start up the screen is blank except for a no signal message
You might wanna try to buy a video card and hook it into a PCI port, sometimes the Integrated video modules fail but the rest of the motherboard works.
Apr 02, 2009 | HP Pavilion a1600n (882780776265) PC...
Computers & Internet Logo
73 people viewed this question
Ekse
Marvin
Marvin
