I have a Toshiba 40XV645U. Works fine except that when TV is turned off then back on it does not recognize the HMDI 1 input (to which the cable box is attached). "No video signal" comes up. So I have to switch input to HDMI 2 and wait for "no video signal" then switch input back to HDMI 1 and it will work fine...until I turn off the TV again. IT does the same thing no matter which HDMI input it used. It's annoying. How do I get it to immediately recognize the HDMI 1 input when the TV is turned on?
I have the same issue with a Toshiba 46XV648U. I talked to Toshiba customer service and the individual I spoke with was not aware of this problem, but they are sending me a firmware update for the TV that "might" fix this.
I assume that you have set the input source selction as in Page 32 and HDMI 1 is solid and and not grayed out. If so check the Preferences menu and see if there is an option for power on set up.
Also look at page 51 about HDMI feature settings. I assume you turn the cable box on first before turning the TV on.
