Spark ignitors on my ge jgp636 stovetop don't work on two rear burners. Tried some trouble shooting by switching wires off the "distributor" where all the wires to the spark ignitors come from. Found that the spark ignitors that didn't work in the rear worked off different positions on the "distributor". After I pulled the wire off the front right ignitor and replaced it none only one of the ignitors worked and the current was going to this one burner regardless of which burner I turned on.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Here
is a tip that I wrote to give details about why your cooktop will not
spark to light the burners..
Cooktop
Range Stove spark ignition does not work
heatman101
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
