The colors are blurry and shadows,will not converge on remote control,65" mitsubishi ws-65511
This model uses a Single convergence IC---a STK-393-110.
If convergence is skewed and will not adjust the chip needs to be replaced.
Most shops get 300 or more for this repair---you can buy the IC on Ebay for about 12 dollars--total parts cost should be under 30 dollars.
I have Start to finish, step by step instructions for this repair in this set--they tell you everything you will need and how to do the repair.
Let me know if you have questions or want the instructions.
If this helped you rate this solution as I do this here for free.
SD TECH
Convergence problem.
The convergence IC's need change, or you need a new convergence board.
You can get The IC's at
www.mcmelectronics.com or a new convergence board at www.partstore.com185 views
